Author Topic: '76 CB750F Patina Redemption  (Read 4103 times)
Offline slikwilli420
  • Master of Disaster
« on: November 08, 2018, 06:14:49 AM »
I need another project like a hole in the head but here we are. Going to do my very best to use parts on hand and keep this one SIMPLE. My Vintage Speed Part Mashup bike is based on the '76F I bought as my first road bike. Over the years I have cut and modified to the point that its so far from stock it retains none of the traits of the stocker. I had felt guilty for cutting up such a nice and original (only exhaust was changed) bike and decided I needed to redeem myself, to myself. I picked up a '76F frame only a few thousand numbers from my original and got the title, so it will all be legit. I kept the seat, tank and a few other key items like wiring, batter box, oil tank/lines, hand controls and wheels/brakes.
The plan here is to keep the patina of things that are in good enough shape not to refresh and only fix what needs to be done. For instance, too much rust on the frame to leave alone so that, the swingarm and center stand will get a fresh coat of paint. The tank and seat are too nice and original to do anything with but use as is.
The idea is to build a bike a guy who was into early supebike racing would have built up on the street. Superbike racing started in 1976 and although the DOHC ruled the day, I still think a privateer may have campaigned an SOHC if that's what they had on hand.
I don't usually believe in budgets because then you just disappoint yourself, but this one will hopefully be done with only a few thousand additional dollars spent with the biggest outlays left being front brakes and triple trees.
Now for the non-stock stuff:
GL1000 forks with custom trees and superbike bars
AP Racing calipers clamping Mark Zero cast iron rotors
Morris aluminum wheels - 2.15 front, 2.5 rear
AP Racing rear caliper with stock F master cylinder
Thinned front rotor to use on rear (same smaller bolt patter as front rotors)
Period shocks (have Marzocchis on there now, maybe find some Fox/Ohlins from the period)
Hondaman electrical bits and new RR
Engine will be a refreshed stock motor with some period tasty pieces like rocker hold down valve cover, trimmed covers, etc
Here is where it sits right now:
Re: '76 CB750F Patina Redemption
« Reply #1 on: November 08, 2018, 08:18:30 AM »
I'm in for this.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: November 09, 2018, 01:11:31 PM »
This is going to be a fun one to follow.
« Reply #3 on: November 09, 2018, 05:02:53 PM »
Are the Morris wheels 18" F&R?
« Reply #4 on: November 09, 2018, 05:41:29 PM »
19" front Don. But the stock wheel diameters were used in early superbike racing anyway so I'll say I planned it that way.  Will run a stock or stock-ish front fender anyway which will look best with the 19" wheel. Really trying to restrain the tasty aftermarket bits I put on this one. Wheels and brakes will be the highlights of this one from an aftermarket standpoint. The rest well will be bog standard as the Brits say.
« Reply #5 on: November 10, 2018, 12:09:37 PM »
The AP calipers are a great period-correct upgrade. I have used Lesters and GL fronts on different bikes, but never Morris wheels.  The Morris wheels have such a great look and are so plentiful in the used market having been used so much with Kawi bikes.
« Reply #6 on: November 10, 2018, 12:19:04 PM »
These are Morris wheels with the actual Honda adapters though. I did find out that I need to get the rotors further away from the wheel to accommodate the caliper. I don't think I'll need to go wider on the fork spread just move the rotors out. Bummer as I didn't plan on making new bearing adapters.
« Reply #7 on: November 10, 2018, 03:22:27 PM »
I haven't seen the Morris wheels with Honda adapters.  The only ones I've seen used on Hondas otherwise required machining for wheel and rotor spacers.
« Reply #8 on: November 10, 2018, 03:48:11 PM »
Nope. These are true aftermarket wheels that you could buy adapters for any common bike back in the day. The hubs are hollow allowing for any disc pattern to be used.
« Reply #9 on: November 11, 2018, 05:10:55 AM »
Be careful what wheels you buy, should be ok with 6 bolt pattern . I saw this one this summer, left the guy my email in case he sells.  A real mag.
 Most of the Kawi wheels are knockoffs.  A real Morris  has removeable bearing plates.
 Great deals on ebay now and then.
« Reply #10 on: May 06, 2019, 09:26:17 AM »
Made some progress. Moved the bike out of the basement and into my reorganized garage. Oddly, still the same amount of stuff in there, but managed to get more room.
Anyway, the front end is on with All Balls tapered bearings. I was trying to figure out how to get clearance for the speedo, keep the wheel centered in the forks and use the stock triples. Well, it turns out you can only have 2 of the three so I chose to ditch the speedo. I will run a GPS speedo mounted inside the stock speedo gauge housing and keep the mechanical tach, or swap that out too, but in either case, keep the gauges looking stock at a glance.
I have the brake caliper adapter plates designed and they are being water jetted now. I will need to get calipers ordered to finish that part of the project but its moving along, and now the bike sits up on its own.
I need to dig up a wire routing diagram for the SS harness as it goes through that silly plastic box and all, but trying to keep some elements stock and some more superbike inspired. The engine that came in my original '76F is on the stand, and was my race engine in 2017, and only needs the charging system put back on and a quick tune and its ready to go again. It won't be ready for a big local show in early June, but hopefully will be all set to debut at Mid-Ohio in early July.
« Reply #11 on: May 06, 2019, 09:33:34 AM »
Marzochhis looking great with the yellow!
« Reply #12 on: May 06, 2019, 11:14:29 AM »
I think they set if off nicely too Sean! Hard to say no for $80 at Mid-O last year.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #13 on: May 07, 2019, 05:50:19 AM »
Following*
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline BigJimG
« Reply #14 on: May 07, 2019, 09:14:59 AM »
In the shop manual PDF, there is a routing diagram on pages 243 & 244.  (237/8 on the PDF search function).
This bike is coming together quite nicely.  I really want a '76 yellow to go with my '75 blue.
Hopefully I can make it to the Kzoo show, would be nice to put some faces with screen names.
1972ish CB750 Chopper Project
Yet another CB Chopper frame
1972 CL175
1973 CB175
1975 XR75
1975 CB750F
1976 CB750F1
1977 CB750F2
1978 CB750F3  (apparently, now I have a full set...)
1991 XR80
« Reply #15 on: May 07, 2019, 09:55:18 AM »
PM a phone number and I can text you the wiring diagram pics
« Reply #16 on: May 07, 2019, 10:37:39 AM »
Ill be at Gilmore with my blue race bike in the show.
« Reply #17 on: April 15, 2020, 09:41:14 AM »
Back on this one too! So much getting done with the quarantine here in Michigan. This is week 5 for me and I have to say, I have gotten more done in 5 weeks than the last year on other projects.
My last update was early May for this one and it has made its way to the forefront of the project list, along with my second race bike, in the Hi-Po forum.
The engine that I raced my first year in AHRMA was the stock '76F engine that came from my original '76F, which also wore this bodywork. The frame is now part of my Vintage Speed Part Mashup project that has a number of Rickman items and a bunch of vintage parts "flare". I found a '76F frame at Mid-Ohio without title for $40 a couple years ago, and went through the process of getting a Michigan title and here we are.
I have installed a set of Tarozzi rear seats make for the 75-75F. I'm not in love with how far out the right peg sits, but they do look good and they feel nice sitting on the bike with the superbike bars, which have a bit more rise due to the GL1000 top triple tree.
The front end is pretty well wrapped up, with a set of 12" Mark Zero rotors, Spondon calipers, held together with custom bearing hubs and caliper brackets. The brake lines from Earls are also fitted and run through a GL1000 splitter mounted on the front of the bottom triple clamp.
I picked up a valve cover with cam tower hold downs a couple years ago and figured it would look the part on this machine so on it went. I cut down each m6 set screw so the same thread was showing above each nut, think it turned out pretty sweet. I also added a full compliment of SS Allen bolts for the case halves and all the covers. I will replace everything I can with SS Allen head from back to front.
Engine wise, it will remain stock for now since a PO threw a drive chain and welded the case halves together. The engine ran great before I raced it and when I raced it so I really have no reason to get into the bottom end. I may refresh the top end with an overbore and a mild cam, but that's it. Ignition wise, I have an ARD mag that I (who guessed it?) picked up at Mid Ohio a few years ago. The mag came with two sets of housings, one that is on the bike now, and one made from 2 that was extended and has since been broken. It looks like everything is there minus a set of wires. I still plan to send it out and have it checked over and will go from there. Too cool to let it sit on a shelf.
I didnt care for the current offering of oil cooler adapters available today so I made my own. New made ones are designed for a spin on filter and most have NPT fittings, neither of which I wanted for this build. This plate will have -8an fittings running through crimped black nylon lines to a small Setrab oil cooler mounted in the space between the horn and exhaust. With the shutdown, the weld shop isnt open so getting the fittings welded to the housing will need to wait. Everything fits up nicely with an F2 oil filter bolt. I also cut down a stock filter housing to remove the fins and with the sandwich plate, looks nice and clean.
The MotoGP Werks exhaust that I picked up from a forum member is now on the bike. The header fits great but with the rearsets on the bike the rear of the exhaust exits at a weird angle. My plan is to get a few mandrel bends and make a new slip on that will more tightly fit the side of the bike and not stick out the 10" it would if I did nothing. Once I can get back to the weld shop that will be all done and ready for the vintage Yoshi can that will be going on. After fighting to get that all apart, I have done a light rehab on it by cleaning up the canister and end caps. It will all get riveted back together along with the original badge.
Last update for now is rear brakes. This was the first AP caliper that I picked up years ago at Mid Ohio for like $20. It will go on an AHM inspired caliper bracket that was used by the AHM Superbike team in the early 80's. I will be using the stock rear master rebuilt and a SS line to match the front.
Offline BenelliSEI
  • 1969 cb750
« Reply #18 on: April 15, 2020, 02:47:21 PM »
Nice mix in this build, watching closely. I have the same issue with a speedo drive on my Rickman (the race bike is totally missing the gearbox for the rear axle and I don’t want to modify the caliper mount and built in spacer (it’s beautifully fabricated and an original Rickman “race part”).
Would like to hear more about your plans to “insert a GPS speed in the stock speedo housing”? Done it before? Would be a great solution for me! Thanks for any info.
« Reply #19 on: April 15, 2020, 04:03:43 PM »
Thanks! I have all the speedo parts for my Rickman, if you need measurements from the drive I can dig it out and take some.
I found a thread on here where someone used a Speedhut gauge that fit nicely inside the stock gutted gauge. Im going to explore that route for this and my new race bike. I will keep the gear-driven tach on this bike and try to possibly get a face to match. On the race bike, there will be no speedo, just a plate covering the face of the gauge but will use a Speedhut tach and go from there.
Offline BenelliSEI
  • 1969 cb750
« Reply #20 on: April 15, 2020, 04:13:51 PM »
I have all the parts, just don’t want to hack into the comp. caliper bracket. I’ll check out speedhut. Thanks!
« Reply #21 on: April 15, 2020, 05:28:24 PM »
Those are some cool period-correct brake set ups (front and rear).  Are you going to stick with the GL top triple and fork length (they are a couple inches longer than 750 tubes as I recall)?
For my Black 750, I ended up ordering shorter tubes (from Forking by Frank) and used an aftermarket top triple.
« Reply #22 on: April 15, 2020, 06:28:42 PM »
With the 14" shocks in the rear I'll only choke the forks up just a bit and see how it handles. Same forks and shock length on my race bike though the top of the forks are even with the stem nut whereas this triple has a drop to it.
