Author Topic: Electrical guru - take a look pretty please  (Read 951 times)
Offline greenjeans
  • 1972 CB750K2
« on: November 09, 2018, 04:48:10 PM »
I have an XR600R that I’m just about finished with.  I want to add a separate DC circuit to run LED lighting - headlight, tail, turn signals and a horn.  Usually, when the XR guys do this, they get a new rewound stator to put out more power.  They typically have a separate output for lighting.  I want to use my stock one.  It supposedly puts put 45-55 watts.  The original stock headlight was 35 watt.  I’m putting a Baja design LED unit in there that is only 26 watt.  Doesn’t sound like much, but it’s brighter than stock.
So, I plan on replacing the stock AC reg with a combo rec/reg unit to get the DC power for my LED lighting.
Does my diagram look like it would work?  Do you think I’d have to isolate/float the ground from either the AC or DC side?   Am I over thinking this?
« Last Edit: November 09, 2018, 04:50:22 PM by greenjeans »
Offline greenjeans
  • 1972 CB750K2
Re: Electrical guru - take a look pretty please
« Reply #1 on: November 09, 2018, 04:51:50 PM »
Here’s what the silly thing looks like now
