Author Topic: #3 carb flooding thru exhaust  (Read 920 times)
Offline rickibrown
« on: November 12, 2018, 09:30:25 AM »
Personal rebuild of carbs all new jets and gaskets synced with gauges. Excellant spark. Problem! Fuel is drowning plug and flowing out of exhaust weep hole 4 into 4 exhaust. Had the carbs off 4 times adjusted float, checked valve with compressed air, checked floats for leaks. all good. Changed plugs. Any suggestions welcome, could it be open exhaust valve ? when hot at 4-5k rpm Top breather is also fuming heavy. Concerned that gas is contaminating oil with blow bye.
Offline jaytee-nz
Re: #3 carb flooding thru exhaust
« Reply #1 on: November 12, 2018, 11:01:55 AM »
This is a "NOT for questions" section - you won't get many answers here.
