Author Topic: Internal coating for exhaust headers?  (Read 1516 times)
Offline Kikemon
« on: January 18, 2007, 04:32:22 PM »
I couldn't find much on this in the archives, so I hope it is not an old topic (seems it should be). I just bought an essentially new exhaust system for my '75 CB400F and wanted to do whatever I could to keep it from rusting for as long as possible. I use the bike as a commuter, it rains all the time here and do not have the option of only running it for >30 minutes to get it good and hot, so it will be parked before fully warmed.  I know a lot of the rusting problem is from condensation from water produced by combustion rusting from the inside. I read one post about zinc coating the inside (how?) and running 2 stroke oil through the gas. Would something like Kreem Blue Shield help? Is there something else like that out there that might help? Or should I just start an IRA account specifically for exhaust replacement as it is only a matter of time...  Thanks for any advice
Offline Geeto67
  • A grumpy
Re: Internal coating for exhaust headers?
« Reply #1 on: January 18, 2007, 05:10:57 PM »
jet hot can coat the inside, I forget for how much but it is not hard to find them to ask (I think it is $200 to do the outside).
I have heard of some guys drilling a very very small hole at the lowest point in the exhaust to allow condensation to run out, I've never done it and I don't recommend it.
Maintenance Matters Most
Offline mkramer1121
« Reply #2 on: January 18, 2007, 05:13:31 PM »
You can do the following as a cheap and effective way to coat the inside of your headers.  Buy some VHT High Heat Cearmic paint, their website says white, and spray a can down the tube (silencer removed).  Do a whole can a pipe, let it somewhat back on the bike and run it to bake the paint.
« Reply #3 on: January 18, 2007, 06:50:09 PM »
You can actually do the old school trick and coat the inside with heavy oil and let it burn down to a crust.
« Reply #4 on: January 18, 2007, 06:57:35 PM »
I've had HPC do inside/out. It does work.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: January 18, 2007, 07:08:59 PM »
Wondered who/what HPC was so I though so might others..
http://www.hpcoatings.com/
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #6 on: January 18, 2007, 07:09:08 PM »
Most shops that powdercoat can also ceramic coat (for high heat applications)..
I had the headers and exhaust on my last racecar ceramic coated inside and out..
Offline dagersh
    • Photos
« Reply #7 on: January 20, 2007, 04:50:21 PM »
I had the Headers and Pipes on My '86 Moto Guzzi Lario Jet Hot Coated.  They are awesome, did an amazing job, and cool down really fast.  Highly recommended.  I wil be using them to coat a '76 Goldwing exhaust and headers.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
