Author Topic: '82 cb650sc cafe project  (Read 26684 times)
Offline kerryb
  • Not a very
Re: '82 cb650sc cafe project
« Reply #75 on: March 19, 2024, 07:16:41 AM »
These are the parts of my intake tract, hope it works...
Offline kerryb
  • Not a very
« Reply #76 on: April 05, 2024, 06:25:36 PM »
getting impatient, wanted to see what it looked like with more pieces.  Good thing, 'cause
I realized I have no lic. plate light.  It will be part of the seat circuit so there will be only one plug for the seat.
Offline Godffery
  • Godffery's Garage
« Reply #77 on: April 05, 2024, 06:46:56 PM »
 Well Good Golly! That's look'n rather Nice!  8)
Offline kerryb
  • Not a very
« Reply #78 on: April 05, 2024, 07:01:11 PM »
Thanks, It's taken quite a while.  the more I get finished, the more stuff there is still to do!
Silly Question:  If the fender is mounted to the swing arm to be close to the tire, it seems it should be adjustable fore and aft to accommodate chain stretch...am I overthinkin' it?
Offline Godffery
  • Godffery's Garage
« Reply #79 on: April 05, 2024, 11:57:09 PM »
Technically that would be the ideal setup, but pretty tricky to accomplish.  I have done a few 'Huger style' rear Fenders mounted to the swing arm, and usually design them to just clear the tire when it's fully adjuster forward (where it's never actually likely to be) then just let the gap increase to where it ends up when the chain tension is properly set. Overall the gap never seemed extreme or unsightly. Also if the fender is painted black, it tends to blend in with the tire anyway.
Offline kerryb
  • Not a very
« Reply #80 on: April 06, 2024, 02:24:46 PM »
Well, we'll have to see if I can make one that works.
Offline Godffery
  • Godffery's Garage
« Reply #81 on: April 06, 2024, 03:28:49 PM »
If you PM me I could send you some pix of a couple I did.
Offline BenelliSEI
  • 1969 cb750
« Reply #82 on: April 06, 2024, 06:40:58 PM »
Just saw the “snorkel” arrangement. Looks very clever! The stuff nobody ever sees is often the best.
Offline kerryb
  • Not a very
« Reply #83 on: April 06, 2024, 06:51:19 PM »
Thanks, I'm excited to finish it, to test my ideas, but bummed that my arthritis will prevent me from riding it more than a few minutes.
« Last Edit: April 11, 2024, 05:52:33 PM by kerryb »
Offline kerryb
  • Not a very
« Reply #84 on: September 29, 2024, 05:16:32 PM »
Time to update this thread and finish the project.
Fender worked pretty good, but I wish I had made it wider to start with.
Offline kerryb
  • Not a very
« Reply #85 on: September 30, 2024, 08:55:14 AM »
After test rides, I can report the intakes mods seem to work quite well.  The seat was a real adventure in material handling, but it’s on and rideable.
Offline kerryb
  • Not a very
« Reply #86 on: September 30, 2024, 09:00:51 AM »
Just gotta remember to look down to be sure turn signals aren’t left on.
