Author Topic: 73 750 Battery question  (Read 926 times)
Offline Gene
  • Chat enuf you too can be a
« on: November 20, 2018, 03:52:46 PM »
Nothing major here - I think. I was swapping out the battery in my bike - just time to do it - and taking off the positive the nut would not budge. So much so that when I tried a wee bit harder the actual anode weakened and broke off. I stuck a wrench on it but, no go.
Could this be an electrical issue? Overcharging? I haven't had any issues with the bike save for the battery on it's last legs. Just curious if this problem has popped up for anyone else before - or if it's even an issue.
The fusebox/electrics/etc. all are clean - no bare wires. I haven't traced the whole harness because I know the PO did. Could it be too much of a draw from the headlamp? About 6 months out of the year I'm riding home in the dark. Up and down on the tach since it's Southern California and there are too many damned ppl here.
Here's a pic. My hunch is I over-tightened it on install and the anode is just weak metal anyway. Curious.
*1973 CB750K3 (Bow)
Offline pjlogue
Re: 73 750 Battery question
« Reply #1 on: November 20, 2018, 05:15:50 PM »
I would think it would be a case of over tightening and then corrosion.  If it were current related, enough to self solder the terminal to the bolt, it should have blown a fuse.  (unless the short was on the battery side of the fuse block and wasn't in the circuit.)  I also think you would have a melted battery wire if it were a short.  Check the wires carefully just to be sure.
-P.
Offline Gene
« Reply #2 on: November 20, 2018, 05:17:30 PM »
Thank you. That's what I was thinking - it would have been a bigger problem if it were current-related. I'll check everything just to make sure.
Thanks again.
*1973 CB750K3 (Bow)
« Reply #3 on: November 21, 2018, 02:30:58 AM »
Used to be a relatively common problem on old batteries back in the 70s when i was a full time mech.
