SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
CB 750 BIG BORE 836cc
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB 750 BIG BORE 836cc (Read 958 times)
olasek18_18@o2.pl
Full Member
on:
November 29, 2018, 07:51:49 AM »
Hi everyone
I want to re-drill my CB 750 on 836cc,
Should I change the camshaft, valves, or carburetors?
IS it possible to align it without changes in the cylinder head?
Any suggestions?
Thank You Guys
Logged
Prospect
Expert
Re: CB 750 BIG BORE 836cc
Reply #1 on:
November 29, 2018, 07:57:27 AM »
Hi
Yes, you can bore out the cylinders to 836cc without changing the rest of the engine or carburetors. Make sure a good reputable shop does the boring and get the clearance correct.
Logged
Current Bikes
1969 CB750 Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
madmtnmotors
When did I get to be a
Really Old Timer ...
Sunny Central Florida
Reply #2 on:
November 29, 2018, 09:06:40 AM »
It depends. The 836 pistons up to a 10.25 CR (Compression Ratio) should be okay but if you up the game to 12.25 CR then you will want to check valve to piston clearances carefully (good practice even at 10.25 CR). At the 12+ CR I would recommend stronger rods as well.
Logged
TAMTF...
Wilbur
Projects:
"Evolution":
http://forums.sohc4.net/index.php?topic=100352.0
"P.O. Debacle":
http://forums.sohc4.net/index.php/topic,126692.msg1441661.html#msg1441661
F2/F3 O-rings:
http://forums.sohc4.net/index.php?topic=113672.msg1300721#msg1300721
Cam Tower Studs:
https://www.mcmaster.com/#93210a017/=t19sgp
Clean up that nasty harness:
http://forums.sohc4.net/index.php?topic=137351.msg1549191#msg1549191
Charging system diagnosis:
http://forums.sohc4.net/index.php?topic=1012.msg8345#msg8345
Get the manuals:
http://manuals.sohc4.net/cb750k/
The Dragon:
http://forums.sohc4.net/index.php?topic=45183.msg1571675#msg1571675
Headlight Switch:
http://forums.sohc4.net/index.php?topic=113986.msg1283236#msg1283236
Branden's leak free top end thread:
http://forums.sohc4.net/index.php?topic=107040.0
Engine Lifting Made Easy:
http://forums.sohc4.net/index.php/topic,58210.msg1684742.html#msg1684742
Static and Dynamic Timing:
http://www.hondachopper.com/garage/carb_info/timing/timing1.html
Airbox Gasket Replacement:
http://forums.sohc4.net/index.php/topic,114485.msg1290000.html#msg1290000
"Café" :
http://forums.sohc4.net/index.php/topic,84697.msg953814.html#msg953814
PD Carb Choke Linkage:
http://forums.sohc4.net/index.php/topic,100352.msg1669248.html#msg1669248
Follow up on your damn posts:
http://forums.sohc4.net/index.php/topic,144305.msg1791605.html#msg1791605
Taiwanese Cam Chain Tensioners:
http://forums.sohc4.net/index.php/topic,155043.msg1774841.html#msg1774841
Gumtwo Seat Cover:
http://forums.sohc4.net/index.php/topic,164440.msg1897366.html#msg1897366
Primary Drive:
http://forums.sohc4.net/index.php/topic,166063.msg1919278.html#msg1919278
Tank Latch:
http://forums.sohc4.net/index.php/topic,165975.msg1919495.html#msg1919495
Shorten your forks:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-shorten-forks-td4042465.html
DO NOT CUT THE SPRINGS!
Clutch How To:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-change-and-adjust-a-clutch-SOHC-td4040391.html
Late model K7/K8/F2/F3 front sprocket cover removal:
http://forums.sohc4.net/index.php/topic,178428.msg2072279.html#msg2072279
630 to 530 conversion:
http://forums.sohc4.net/index.php/topic,180710.msg2094423.html#msg2094423
Sent from my Tandy TRS-80!
PeWe
Bike almost back to the 70's 2015
Reply #3 on:
November 29, 2018, 09:41:09 AM »
The higher CR 10.25/10.5-1 need a cam with more overlap than stock, right? This reduce the dynamic compression less hot and risk for pinging
Porting the head is recommended when refurbish the valves and seats. Use stock valves if they are OK. Mild cam as webcam 41 can use stock springs.
More fun with next step of cam and stronger springs.
My 836 with 80-83 rwhp (depending on cam) ran fine with stock rods.
Logged
CB750 K6-76 970cc (Earlier 1005cc JMR Billet block on the shelf waiting for a comeback)
CB750 K2 -1975 build thread
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
