Author Topic: Points cable route on 400 four  (Read 1279 times)
Offline morefour
« on: November 30, 2018, 05:00:13 am »
Hi All. Does anyone know (or can kindly have a look!) at the route of the sleeved (heat resistant) cable that goes from the points to the connector near the battery. I have 3 clips. Two are 'U' shaped with fixing hole and one is smaller 'U' shape with fixing  hole and it looks 90 degrees to other two. I assume they screw to clutch cover but unsure what fixing bolts to choose for clips and where the odd shaped clip goes. Unsure if it goes above or under the Kickstarter. This is my last job of a 12 month rebuild from a basket case before I start the engine!! Many thanks in anticipation.
