Author Topic: Me & my 77 CB550K say hello  (Read 786 times)
Offline goodtryer
« on: December 02, 2018, 07:53:05 PM »
Hi All,
Been a lurker for quite a while but need to get enough posts to start sending PM's and posting pics. So howdy from Texas!
Picked up a solid-running 550K a few months ago and have been reading and learning how to get it into shape. I've done most of the basics but have been putting off cleaning the carbs until winter settles in. So far, I've put close to 1000 miles on it around town and some small back roads around here. It runs strong at the lower end of the rev band but loses strength above 6-7k rpm.
Anyway, thanks in advance for all the great info and helpful people around here.
Cheers!
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline rocket johnny
Re: Me & my 77 CB550K say hello
« Reply #1 on: December 03, 2018, 07:24:15 AM »
welcome from western colo. !   post a photo when you can
« Reply #2 on: December 03, 2018, 04:38:59 PM »
Welcome from TN. Loosing power at that range is bad as that is where it likes to live for best performance...
David
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #3 on: December 03, 2018, 06:14:04 PM »
Welcome from NE MN,
Does the power loss come after the engine is good a warm?   On my bike the spark caps would heat up and cause surging and a loss of power.  Replaced the caps and the problem solved.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline Caneel14
« Reply #4 on: December 04, 2018, 03:49:20 PM »
Having fun with my 77 550k, can you post some pics?
Offline goodtryer
« Reply #5 on: December 05, 2018, 07:40:24 AM »
Thanks for the replies. Really appreciate all the info and the helpful advice on this site.
Here she is. Not all that much to look at but it sure is fun to ride; it'll be even better when this little power issue gets solved. The yellow is kind of loud and the paint job isn't high-quality but it got a nice shine to it after a little work with the polishing compound and wax. The PO put a F-style side cover on the right and couldn't understand why it didn't fit right...
Anyway, I've done a lot of the basics (points adjusted, valve clearance, plug gaps, cleaned gas tank strainer and petcock screen, fork oil, engine oil, added carb drain tubes, adjusted drive chain & timing chain, moved the battery ground connection to where it belongs, synchronized carbs, changed brake fluid, etc.) Still need to remove/inspect/clean the carbs but I'm putting that off until the last of the riding days are gone this year, probably during Christmas vacation.
MD: that's a great tip! I have not tested or even inspected the plug wires & caps. I'll do that tonight. And yes, the power loss is when the engine is fully warmed. It seems worst when I just try to slowly roll into the higher revs. It just hesitates and sloooowly revs up to max of 4500 or 5000. However, if I'm aggressive going through the revs and gears, the engine will get up above 7000 and feel strong as long as I stay there (which isn't usually that long; I'm mostly a casual rider).
The electrics on the bike seem solid. I've had no problems with the battery or using the starter and all the lights work, etc. So I don't think it's a charging issue. But maybe the coils & caps... great hint!
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline MD
    • MN North Woods
« Reply #6 on: December 05, 2018, 05:48:05 PM »
Could be the caps.  I could run to red line in 1st and 2nd with out a problem.  Cruising speed in 5th 4-5000 rpm  the bike would surge.
-MD
