Author Topic: CB550 white smoke after top end rebuild  (Read 3522 times)
Offline JB Stellies
  • 76 CB550
« on: December 05, 2018, 08:43:16 am »
I did a top end rebuild after incorrect installation of tappet cover resulting in bent exhaust valves (noob mistake- followed workshop manual without watching youtube tutorials). Now the bike is smoking like a two stroke. I outsourced the valve replacement as I did not have the tool to compress the valves and the mechanic ensures me that the valve guides were not cracked and that valve stem seals are OK. I used aftermarket generic o-rings on the oil channels either side of the head. If these were not thick enough, could it result in white smoke/what would the symptom be? I have ridden 15km, the bike is running well (other than the white smoke) and there are no visible external oil leaks. The bike was not smoking before the top end rebuild and I did not touch the bottom end so I am confident that the rings are OK.
Re: CB550 white smoke after top end rebuild
« Reply #1 on: December 05, 2018, 09:08:16 am »
White smoke is water vapor, generally.
Blue smoke is oil smoke.
Are you certain that water condensate in the exhaust is not the source of the "smoke"?  Have the exhaust been thoroughly heated to flash off the condensate?
Are all head pipes getting evenly hot?
Offline JB Stellies
  • 76 CB550
« Reply #2 on: December 05, 2018, 10:48:19 pm »
I am pretty sure it is oil and we are talking about a large amount of smoke. It is worse at first start up but smokes heavily and consistently thereafter. I will check if all exhausts are heating up evenly when I next ride.
Offline JB Stellies
  • 76 CB550
« Reply #3 on: December 05, 2018, 10:52:28 pm »
PS - and yes, after 15km I think the bike was pretty hot and any condensate and residual oil from the rebuild should have burnt off. Thks
« Reply #4 on: December 06, 2018, 08:22:40 am »
Tell us how you routed the top engine vent hose.
Can the crankcase still "breathe"?
Offline JB Stellies
  • 76 CB550
« Reply #5 on: December 07, 2018, 07:37:48 am »
I have not fitted a vent hose.
Offline Deltarider
  • Another big liar has to face the truth.
« Reply #6 on: December 07, 2018, 07:54:22 am »
Well, there's the source of your smoke, probably
CB500K2-ED Excel black
« Reply #7 on: December 07, 2018, 09:22:43 am »
Is the hose nipple open or plugged?
Offline JB Stellies
  • 76 CB550
« Reply #8 on: December 12, 2018, 07:47:00 am »
Vent nipple is open, photo attached tv. Have been running it without a hose since I got tbe bike with no problem.
« Reply #9 on: December 12, 2018, 08:09:33 am »
 My buddy ran across a breather tube filled with silicone, it caused a similar problem. Just my friends experience.
If you love it, set it free, if it stays it's probably one of my 750's.
« Reply #10 on: December 12, 2018, 08:18:24 am »
...Except for the bugs that crawl in and nest, or abrasive dust invasion.  Rain or wash water ingress?
And, if you do get excessive piston ring blow by, the engine oil sprays out of there covering the entire rear of the bike.  If it weren't a required item, why do you think Honda went to the expense of installing one on every bike they sold?  Give them a little credit, please.
Anyway, it's good that you didn't plug it off.  We can check crankcase pressure build up off the possible cause list.  I was looking for cheap and easy fixes.  Now it warrants a more serious investigation.
If you have excessive oil smoke, it is getting past the valve guide seals or the piston rings. (or leaking onto the exhaust system.)  Time for a leak down cylinder check, or at least a compression check, to ensure mechanical health of the cylinders.
Do the spark plug deposits show anything interesting?  Are they the same for each cylinder position?  Did you verify each head pipe runs at about equal temperature?  We need to know if all four pots are burning, or if one is just pumping fuel/air without igniting. If the latter, white fuel vapor out the exhaust is a possibility.
Have you checked for spark at each position?
Offline JB Stellies
  • 76 CB550
« Reply #11 on: December 12, 2018, 08:52:42 am »
Thanks gents. New rings about 1000km ago and did not touch the block and it was running fine before I took the head off so I am confident rings fine. My guess is that mechanic did not check for cracked valve guides and that one or more exhaust valve guides cracked when the valves bent. When I asked the mechanic if he checked he said he would need to check with the guy who did the work so my guess is he did not give clear instructions to his junior. Attached photo of smoking bike.
« Reply #12 on: December 12, 2018, 08:58:01 am »
You have not felt any stinky warm oil smell right up in your face while waiting for green light with warm engine?
My CB750 K6 had a long hose from valve cover breather going backwards on right side to the rear passenger foot peg. Old hose hardened and cracked. Now a shorter one ending just behind main foot peg.
Std car 1/2" oil/heater hose work fine. A little bit thick... Honda used thinner walled hose without braiding.
CB750 K6-76 1005cc JMR Billet block.
Offline JB Stellies
  • 76 CB550
« Reply #13 on: December 12, 2018, 09:02:02 am »
Thanks, I will fit a hose when I put the engine back together again after sorting out the cause of the smoking.
« Reply #14 on: December 12, 2018, 01:36:32 pm »
If the valves were bent i would be 90% certain the guides were broken somehow. If you fit new they need to be ACCURATELY reamed to size and the seats re ground to suit.
The size reamer is not a "standard" size so unless it is a shop that does a lot of Hondas an adjustable one tends to get used and they are simply not good enough.
Offline JB Stellies
  • 76 CB550
« Reply #15 on: December 13, 2018, 06:21:34 am »
Thanks Bryanj. Will have a careful look at valve guides when it is in pieces again. I have a full spare engine in parts and may be better to use that head but cam chain tensioner broke on that engine and cam chain slipped so not sure what damage that may have caused to the head if any. Cannot see any visible damage to the head.
« Reply #16 on: December 13, 2018, 10:03:17 am »
Easy check to see if valves are reasonable is to stand head on exhaust outlets then fill inlets with gas or keroseen and see if any apears in combusion area then put head on inlets and fill exhaust. Easier to see which, if any, valves are leaking than the book way of filling combustion chamber.
Offline JB Stellies
  • 76 CB550
« Reply #17 on: December 13, 2018, 10:25:30 am »
Thanks Bryan, great tip.
Offline calj737
  • I refuse...
« Reply #18 on: December 13, 2018, 11:22:30 am »
This will only tell you whether or not the valve face is seating do sealing fully, not whether the guide is worn. You could easily have carbon build up on the valve face, preventing full seating, but good guides. Conversely, worn guides that under operating conditions allow the valve to move off their axis, but freshly lapped faces that seat.
Unless I’m missing something?
Offline JB Stellies
  • 76 CB550
« Reply #19 on: December 13, 2018, 12:12:44 pm »
Makes sense unless you can look for gasoline leaking through on either side with that test (valve seat and stem ends)?
Offline calj737
  • I refuse...
« Reply #20 on: December 13, 2018, 12:20:19 pm »
Maybe I made my point in a confusing fashion, or I’m confused. I see where that technique addresses the valve seat. But I don’t see where it addresses valve guide wear.
Wasn’t that your point with this post?
« Reply #21 on: December 13, 2018, 01:08:06 pm »
It doesnt asses guide wear BUT it gives you a good idea of the valve/seat condition BEFORE you spend any money especially on a used head of unknown condition.
We already know that the fitted one has problems and when you get to valve/guide/seat replacement or repair it is frquently far more cost effective to find a good used head.
Offline calj737
  • I refuse...
« Reply #22 on: December 13, 2018, 03:00:46 pm »
That’s what I thought. Thanks for the clarification.
Offline JB Stellies
  • 76 CB550
« Reply #23 on: December 13, 2018, 10:02:09 pm »
Thanks gents! Understood.
Offline JB Stellies
  • 76 CB550
« Reply #24 on: December 13, 2018, 11:06:36 pm »
I need to order a gasket set from the US so will only tackle this project in January. Will keep you all posted then. Thanks to everyone for input and advice. My experience working on multi-cylinder four strokes is very limited.
