Author Topic: weirdly loud noise from engine - youtube link posted  (Read 4890 times)
Re: weirdly loud noise from engine - youtube link posted
« Reply #25 on: December 19, 2018, 06:56:18 PM »
What you look for is a bare ring around the piston, or a crescent where something is knocking carbon off.
Offline Xander^
« Reply #26 on: December 20, 2018, 05:50:59 AM »
I couldnt see much more than just to top of the piston.. only a bit of the cylinder wall, lookes like minor scratches but could be from honing. Couldnt see deep enough to notice a ring.
SCOTTLY;
I have taken the exhaust off 2 times when i did two oil changes during first start up, the pipes are tightened well..
1977 CB750K cafe
Offline Xander^
Re: new weirdly loud noise from engine - youtube link posted
« Reply #27 on: December 20, 2018, 05:36:02 PM »
new scary squeaky sound coming from engine when i turn the pistons...
1977 CB750K cafe
« Reply #28 on: December 20, 2018, 06:16:26 PM »
 Any way you look at it, it's coming apart, if not now,  then with further damage.
Do you have a broken rocker or cam ?
« Last Edit: December 20, 2018, 09:20:01 PM by 754 »
« Reply #29 on: December 20, 2018, 06:19:23 PM »
 When I had a valve sticking once it was a very clattering noise.
 Check valve clearance,..
 Valve can stick from being bent , not just being tight..
Offline Xander^
« Reply #30 on: December 20, 2018, 06:25:38 PM »
yea... ill have to check valve clearance.. the thumping sounds might be from that...
what you think that squeaky noise is? pistons not going up and down straight?
1977 CB750K cafe
« Reply #31 on: December 20, 2018, 06:27:17 PM »
Do you have oil on both sides of the cam?
« Reply #32 on: December 20, 2018, 06:45:23 PM »
I agree. At the least, the cam cover needs to be removed; I'm now wondering if one of the cam sprocket bolts has backed out and is smacking into the cam chain passage, causing the loud knocking??
« Reply #33 on: December 20, 2018, 07:06:23 PM »
 I don't think it would be loud.
 A sticking valve though does not come down, then it gets hit/hammered when it has like 130 thou clearance.
 I was warned when I told someone about the clicking my bike would get, that it was a sticking valve.. but I was told that by only one person....but he was right.
 If that is the case here  should be able to hear where it is by putting a dowel  on different spots on the head and listening.
 Either way  it's coming apart..
« Last Edit: December 20, 2018, 09:21:42 PM by 754 »
« Reply #34 on: December 20, 2018, 07:14:04 PM »
The loud noise is more than clicking from a stuck valve, or extremely loose tappet??
Offline Tracksnblades1
« Reply #35 on: December 20, 2018, 07:59:38 PM »
Knock sounds like crankshaft speed...
Age Quod Agis
« Reply #36 on: December 20, 2018, 08:40:28 PM »
 Pistons in backwards? That can make the intake hit the piston top.
Offline Xander^
« Reply #37 on: December 21, 2018, 09:26:32 AM »
That is a possibility too.. i got a claymers and hanes manual and im gonna pull up some videos i guess also, gonna go throught everything piece by piece
1977 CB750K cafe
« Reply #38 on: December 21, 2018, 09:54:34 AM »
 Just read the manuals, everything you need to know is in there....
 Takes very few tools, simplest of engines..
 Read it, re-read it, try to absorb it.,
I think they guys that rely mostly on video, are always back here asking questions.
« Reply #39 on: December 21, 2018, 12:29:49 PM »
+1 754,
Honda service manuals are the Japanese equivalency to the old Chinese proverb TAMTF. Only in Honda terms.
« Last Edit: December 21, 2018, 12:33:07 PM by Tracksnblades1 »
Age Quod Agis
« Reply #40 on: December 21, 2018, 12:35:06 PM »
Did you have the head decked by a machine shop before rebuild?
Get a $15 borescope (ebay) and hook it to a phone or tablet.  Look down thru the plug holes for piston top wear.
« Reply #41 on: December 21, 2018, 01:23:08 PM »
 I had a piston on a VW come apart at the ring groove once. It makes an interesting noise, It was still running but the two piston halves collided every power stroke. It was a good excuse for an 88mm big bore kit. My next lesson was about air cleaners with nuts and bolts inside.
Offline Xander^
« Reply #42 on: December 21, 2018, 03:47:10 PM »
yeah the gent who rebuilt the top end machined it nice, even said took down a fraction of a millimeter which was suppose to add a bit more compression and power i guess
im gonna pull off the cam cover anyways but ill look up those borescopes..thanks
1977 CB750K cafe
« Reply #43 on: December 21, 2018, 04:06:03 PM »
You might be able to see the top of piston through spark plug hole better at BDC. If you have determined what or which side is knocking or screeching it would narrow how many holes you got to look down... It does have that " I WANT OUT " sound....
You'll find it....
« Last Edit: December 21, 2018, 04:14:43 PM by Tracksnblades1 »
Age Quod Agis
