Author Topic: Petcock leak  (Read 966 times)
Offline Mr.Mazza
  • The man from down under
Petcock leak
« on: December 12, 2018, 04:17:10 AM »
Hey guys
My 750K4 petcock is slowly leaking
Two questions, how does the tap attatch to the tank?
Secondly how many seals need replacing, is it just an O ring to the tank or much much more?
Driving a car is watching a movie, riding a motorcycle is starring in the movie
Re: Petcock leak
« Reply #1 on: December 12, 2018, 05:01:01 AM »
 Under the removable float bowl and filter screen there are two screws with fiber washers that connect the petcock to the tank. They can cause a leak if bad. The top of the petcock where it mounts also has a rubber gasket. Also behind the petcock handle if you remove the two tiny screws on the face plate is a rubber 4 hole gasket that when bad can also cause a leak.
  Where is it leaking at exactly, through the carbs or externally out around the petcock ?
Re: Petcock leak
« Reply #2 on: December 12, 2018, 08:06:54 AM »
There are seal kits available from I think K and L .. blue box. And petcocks
 I tried repairing two of my originals but they seemed to keep leaking. Ended up replacing with  the after market.
 If you are leaking gas into your motor it could hurt it  watch you oil level.
 I think mine developed cracks internally,  causing them to leak.
Offline Mr.Mazza
Re: Petcock leak
« Reply #3 on: December 12, 2018, 11:12:59 AM »
Thanks guys!
Its leaking externally very slowly
Ill just source getting a whole new one
Offline Deltarider
« Last Edit: December 12, 2018, 11:30:53 AM by Deltarider »
CB500K2-ED Excel black
Offline Xander^
Re: Petcock leak
« Reply #5 on: December 12, 2018, 01:30:20 PM »
I just had this problem and only found out when i filled the tank with gas... but honestly the easiest and best fix would be a whole next petcock. I bought one for like 15$ on 4into1.com
1977 CB750K cafe
Offline Mr.Mazza
Re: Petcock leak
« Reply #6 on: December 12, 2018, 05:10:04 PM »
Ordered a brand new tap from wemoto
$60AUD and Ill have it Monday
