Author Topic: Swingarm bushings all I need?  (Read 2302 times)
Offline 68grandprix
« on: June 06, 2005, 07:47:39 PM »
I was sitting on the bike today with it on the centerstand and when I pushed the back brake I noticed the swingarm moved 1/8-1/4" side to side. Will swingarm bushings($26+ a piece Ouch)fix this or do I also need something else? Thanks, Jimmy.
Offline Clyde
Re: Swingarm bushings all I need?
« Reply #1 on: June 06, 2005, 11:25:27 PM »
You do not mention what bike, but if it is the typical Honda arrangement, then you will also probably need the centre sleeve/collar.
If you think the bushes are expensive......  There are several needle roller conversions, that appear on eBay from time to time.
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline oldbiker
  • I HATE RAIN
« Reply #2 on: June 07, 2005, 02:27:05 AM »
When replacing these bushes, you should also check the spindle for wear.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: June 07, 2005, 04:27:56 AM »
You can find bronze bushings on eBay too, for 1/2 the price you mention.  Last year I picked up a NOS sleeve and a set of bronze bushings.  I hope to install them in the next couple of weeks.  Keep your eyes peeled.
« Reply #4 on: June 07, 2005, 04:36:20 AM »
The bushes are cheap, but the sleeves are expensive, quite often they're badly pitted by rust caused by no maintenance and water ingress. Because I have my own lathe, I machine the sleeve then turn up new "undersize" (smaller ID) bushes.
If your sleeve is still a close fit in a new set of bronze bushes (you'll need to install them to check as the ID tightens up slightly when the bushes are pressed into your swingarm) just grease it up and shove it back in! Cheers, Terry. ;D
« Reply #5 on: June 07, 2005, 05:07:51 AM »
Doesn't everyone have a lathe in the basement???? ;)
« Reply #6 on: June 07, 2005, 06:48:59 AM »
As an ex Mechanic the steel sleeve ie always more worn than the composite bushes and all should be replaced as a set. Here in UK bushes £8 each and spindle £25
Offline 68grandprix
« Reply #7 on: June 07, 2005, 05:55:54 PM »
The only bushings I see say they are for 76-79 Cb750s. These had different bushings? Thanks, Jimmy.
