Author Topic: What is the purpose of this screw on the carb plate?  (Read 1065 times)
AwesomeCB
« on: December 20, 2018, 05:14:58 AM »
What is the purpose of this spring-loaded screw on the carb plate? I looked but couldn't find anything on it...
Re: What is the purpose of this screw on the carb plate?
« Reply #1 on: December 20, 2018, 07:13:44 AM »
What bike?  Should we guess?  or do we have to assume you are talking about yours and look thru your older posts to figure out what bike you have?  :-\
could be the idle set screw, or the fast idle cam set screw....help us out with a picture  ::)
« Last Edit: December 20, 2018, 07:15:33 AM by flybox1 »
AwesomeCB
« Reply #2 on: December 20, 2018, 07:27:48 AM »
Sorry, I should have been clear. It's a CB750K6.
Funny, have thought you would have had the experience to tell by simply looking at it by your response. You seem quite knowledgeable about a lot of things.
« Reply #3 on: December 20, 2018, 07:38:37 AM »
Sorry man, im not seeing any picture in your original post.  If you posted a URL, can you attach a pic instead?
Offline pjlogue
« Reply #4 on: December 20, 2018, 07:40:15 AM »
I believe it's the full throttle limit adjust.  In your picture the linkage plate to the right of the screw should be in line with the screw.
See attached pic.
-P.
AwesomeCB
« Reply #5 on: December 20, 2018, 07:47:49 AM »
See attached pic.
-P.
Yes, that's it, thanks. This plate was in a box of parts and I did not realize the plate and screw normally lined up. It's clear now, thanks.
