So after the initial startup i noticed it wasnt running on all cylinders, guess this is because of fouling the sparkplugs when running it on the starter to make sure oil and oil pressure was getting everywhere before starting. Since i didnt have any new plugs i borrowed a few Dr7es plugs from the other bike just to get it running. From the explanation the Dr8es that are currently in now are a hotter plug with longer insulation, is it wise to run these? My guess is that the bike will run hotter with the cam since you would want to rev it more to benift from it more. Im about to order a box of dr7es for my originals, should i get a another box of 7s or get the 8s for this bike? Is there any downside to running a "too" hot plug?
Now not to sound like a total cheapo but when new plug foul, can you clean them? Seems like a waste to throw out plugs that havent seen any milage on them. but seems hard to reach all in the bottom of the procelin body with a brush. From my understanding, the engine selfcleans the plugs once it reaches the optimal temp. could one heat em with a torch to simulate the same effect?
Now it sounds better but i might have to make some kind of end plug for smoother evening rides when one would not want to wake the whole neighborhood up. It is essentially an open pipe. thinking of just making a round alu piece and drilling some holes out so to break up the sound just a little.
Bike seems to run fine with the standard ingnition timing, i cant myself hear any weird noises, just the normal clattering from the clutch when at low idle.
And about all that about the starter not being able to pull the cam round was just BS, might have been a bad battery or some failing connection causing voltage drops.
