Author Topic: How do you transport your bike?  (Read 2920 times)
Offline juntjoo
« on: December 22, 2018, 01:52:50 PM »
I currently use two aluminum ramps to walk(and throttle. Not that strong) my bike onto my truck bed which undoubtedly I'll get better at but dang it's difficult and scary. Probably just scary. I then put it on the kickstand and ratchet strap it around all forks. Holds well. But I'm considering other possibly easier options. I'll be doing this weekly, hence the desire for the easiest method.
Anyone know about and have an opinion on these?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fp%2F20023340417%3Fiid%3D332790715138
Will this put unused miles on the odometer? Will it significantly wear out chain, tire and other parts? Nah. Right?
I checked out the carrier type you stick in the trailer hitch but I've read enough reviews about them being flimsy or limit your top speed to 45mph. But if there was one that didn't have the drawbacks I'd consider it as it leaves your bed empty and is way easier.
If I stick with the truck bed I'm considering one of these "lock n load" products:
https://www.btosports.com/p/RRLNL/option/05-1010*778292?utm_source=google&utm_medium=cpc&utm_campaign=gs_allproducts&utm_content=71337303348&utm_term=&matchtype=&adposition=1o5&device=m&adtype=pla&product_id=05-1010&product_country=US&gclid=CjwKCAiA3vfgBRB9EiwAkfpd3JQkWRnVxLsggqkL7PnDmF_F3U6NOOgrN6PHcj_1iSEbb-ffBX702xoC6dIQAvD_BwE
bolted to a floor of ply wood in conjunction with a good sized wheel chock.
Anyone ride up their ramps onto their truck beds? I feel that would be easiest if you got good at it but I'd hate to mess up that stunt.
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline Gordon
  • 750K1, 550K2
Re: How do you transport your bike?
« Reply #1 on: December 22, 2018, 02:08:49 PM »
I'm assuming a small trailer is not an option?  Because that would be optimal.
The one that tows with the rear wheel on the ground would probably be fine, but you'll want to remove the chain.
Offline juntjoo
« Reply #2 on: December 22, 2018, 04:13:11 PM »
Hmm, I was worried about the chain issue. Twice a week sounds like a pain. Or maybe it's easy. I've never done that. I'll look into it...
-Ben
82 Nighthawk 650..
Offline innovativems
    • Innovative MotoSports
« Reply #3 on: December 22, 2018, 08:19:04 PM »
Baxley wheel chock in the bed works great. Also Moto Tote hitch carrier is great too
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #4 on: December 23, 2018, 01:01:55 PM »
      borrowed a trailer back in the day. But, even though I felt I tied it down pretty good, the motorcycle still managed to
     move a little, over to one side (making it not being straight up & I had to stop and redo my straps.
    So, some time later, I bought a 3 rail motorcycle trailer, a few years after that and it worked okay, though I still was
   somewhat of a chore to load up a motorcycle, of any size and the tiedown locations, weren't positioned the
   best. So, I have redone that & I have an electric winch now, with a remote type switch, to operate it & if I am by
   myself, I can use the winch, to help me load it up. But then, I am pushing 72yrs of age, so I need some
   assistance on some things.  ;)
Member # 1969
Offline juntjoo
« Reply #5 on: December 23, 2018, 01:51:41 PM »
Winch. Good idea since occasionally it may not be running and I won't always have an incline to make it easier. So I'm now thinking load into bed with or without winch depending on need, secure with chock and that lock n load device I linked to above and ratchet strap rear if need be.
« Last Edit: December 23, 2018, 06:56:44 PM by juntjoo »
-Ben
82 Nighthawk 650..
« Reply #6 on: December 23, 2018, 02:36:54 PM »
Here’s my setup when I don’t use my trailer
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #7 on: December 23, 2018, 03:03:41 PM »
Winch. Good idea since occasionally it may not be running and I won't always have an incline to make it easier. So I'm now thinking load into bed with or without winch depending on need, secure with chock and peg securing device I linked to above and ratchet strap rear if need be.
I would definitely not winch up a ramp into a truck bed.  A trailer works because the drop isn’t far.  Into a truck it’s gonna put pressure down on the forks and wheel, which you don’t want up a ramp.  Would only work with a wheel skid or a pricey bed mounted carrier that lifts bike into truck.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline rb550four
« Reply #8 on: December 23, 2018, 03:33:00 PM »
  The open bed of a pick up truck with a hoop in the plywood was always my choice ( if it was empty) , until I bought a trailer.
The landscape trailer is allot closer to the ground with it's own ramp/rear gate. So much better than making a mad dash up a 2x 10 TJI. The TJI part is pretty good when backing a machine down it if you have front brakes, it's all a crapshoot with no brakes.  I use the TJI as s guide so the machine doesn't slip off the ramp...still not fool proof .
   I put a hoop center of the trailer, great for a single ... tie the bars to the front corners and the rear shocks to the side, that usually works well on the highways, but I do check the ratchets more often on side roads. I had one pop open on a bumpy road once.  I carry 2 bikes on the trailer when  I can (one on each side of the hoop) because it won't bounce so much and it seems more responsive and predictable  especially when backing  up.
  I'd like to try out an enclosed trailer some day and secure the load from bugs, weather,and theft. There must be drawbacks to the enclosed trailer I suppose , but can't say  since I haven't tried one yet.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #9 on: December 23, 2018, 03:41:02 PM »
What are hoops in plywood?
« Reply #10 on: December 23, 2018, 05:53:06 PM »
 I usually borrow my brothers ramp gate trailer. Way easier than ramping up into the truck unless there's a hill or a ditch nearby. I really want to build a drop bed trailer with clamshell fenders off an antique car.
Offline juntjoo
« Reply #11 on: December 23, 2018, 06:54:04 PM »
Ah yes, I looked that one up. A bit pricey and my issue with this type was that no matter the price range there were some stories/reviews of customers ruining their bikes with duds I guess. And I'm sure it's a small but if you get a bad one it'll be more than an 'ah shucks'. Your bike looks light!
-Ben
82 Nighthawk 650..
« Reply #12 on: December 23, 2018, 07:16:07 PM »
There are no duds with the moto tote units.  Rock solid.  This one is rated to 500 lbs and hauls my rc51 all the time.  The horror stories are the cheap ones.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Cougars750F0
« Reply #13 on: December 23, 2018, 07:20:03 PM »
I use a Chevy Astro LS for work and to haul bikes. I just pop out the two quick release seats (witch are out most of the time) and use a ramp. It sits low so its pretty easy and if there is a hill nearby its a breeze. Then strap it down to the anchor's for the seats. It doesn't budge even in a panic stop. The downside is you can't have taller bars or mirrors unless you turn them down. With the factory dark tint and that it looks like a soccer van it not as much of a target to thieves. I've had pick up trucks and cargo vans targeted around it and they don't think I'm carrying tools ;D
« Last Edit: December 23, 2018, 07:27:57 PM by Cougars750F0 »
1970 Honda / Yoshimura 810 with ported head, 1968  Honda CB450 5 speed European model, 1973  Triumph Bonneville 750 twin carburetor model, 1975 Honda 750F0 Super Sport, 1977 Honda 750A
ken65
« Reply #14 on: December 23, 2018, 08:57:36 PM »
 A mates got an enclosed van with tie down points etc. Use a ramp to get it in but will never be a one man option for me as my poor old knees have had it and once its at the top of the ramp I cant go any further.
Offline juntjoo
« Reply #15 on: December 24, 2018, 01:54:42 PM »
I def read a couple bad reviews on Amazon and not many reviews total. But I guess those are the ones that will speak up and maybe it was user error. I'm just going by initial glance which  is all I have to go by. I just don't like the results of really bad luck with this type transportation. But I still may decide to go this route as it's way easier than the others.
-Ben
82 Nighthawk 650..
« Reply #16 on: December 24, 2018, 01:57:44 PM »
Not sure which reviews your seeing.  They have top reviews on amazon.  You do assemble it and that could definitely lead to an issue if not done right.  I use mine all the time on. Long trips to deliver and pickup
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #17 on: January 07, 2019, 05:58:56 PM »
I use my utility trailer and strap the bike at 4 corners of jam it diagonally in my a truck 2 straps on the handlebars on through the rear wheel or rear part of the bike to the back 2 hooks in the bed. Haven't dropped one or had them scoot around since i started doing it like that.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline Bankerdanny
  • Endeavor to persevere
« Reply #18 on: January 07, 2019, 06:00:29 PM »
I rent a motorcycle trailer from U-Haul, $14.95 per day.
« Last Edit: January 07, 2019, 06:03:15 PM by Bankerdanny »
Offline spotty
« Reply #19 on: January 07, 2019, 06:47:37 PM »
use good tie downs whatever method you choose
i blame Terry
Offline CBJoe
« Reply #20 on: January 07, 2019, 06:57:11 PM »
Thats a pretty cool piece if kit...I see they have a unit rated up to 600lbs.  That should cover almost all my bikes minus my big guzzi as long as taking it up to the max rating is possible.
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Johnie
« Reply #21 on: January 07, 2019, 07:07:13 PM »
Trailer
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Tracksnblades1
« Reply #22 on: January 07, 2019, 07:19:53 PM »
I have 3 tandem trailers, 15,000gvw, 2) 8,000 too heavy for one cycle. Usually loaded with Fuel tanks welders or small equipment. I usually have to rent U-Haul motorcycle trailer. All day rate here is $24.00 with their insurance $33.00. Sometime this quicker and a lot less work.
Age Quod Agis
« Reply #23 on: January 07, 2019, 08:16:16 PM »
They are really well built.  This is the 600 lb unit.  I haul my rc51 with it a lot and trust it.  I’m a dealer for them if you ever are looking for you, I can take care of you.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #24 on: January 08, 2019, 03:49:15 AM »
Using my trailer.
