Author Topic: A rebuilt CB350K4 is making a "Chirping" noise.  (Read 2598 times)
Offline 34barab
« on: December 22, 2018, 10:20:09 PM »
Nearing the end of the engine rebuild after a complete tear down, I put 2 liters of fresh oil in the bike and buttoned up the crankcase side covers.  With the engine back in frame I tried the electric starter, which worked well, but I noticed a chirping coming from the engine.  It keeps cadence with the engine cycles, usually at a particular point in the cycle.  I think it's coming from left side of the engine, down low, possibly the alternator.
No gas yet, carbs are on, exhaust pipes are off.  I don't want to run it yet.  All thoughts, suggestions, comments, etc. are appreciated.  Thanks
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Offline cb750f-2010656
  • Call me Golden
  • F*©k 'em. Then say, F*©k 'em!
Re: A rebuilt CB350K4 is making a "Chirping" noise.
« Reply #1 on: December 22, 2018, 11:46:17 PM »
Did you lube everything up good before installation?  Try priming the oil system before initially firing it up.
76 CB750F (Old Girl)
85 Rebel 250 (Little Girl)
96 Fleetwood Brougham (USS Great White)
Offline robvangulik
  • Honda Fourever
« Reply #2 on: December 23, 2018, 02:37:36 AM »
The alternator runs oilfree so it's easy to take the cover off to see if there is unwanted contact anywhere...
BTW what type/year is a K4?
« Last Edit: December 23, 2018, 02:41:10 AM by robvangulik »
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: December 23, 2018, 03:39:28 AM »
This is while the bike is being cranked over but not running?  Very common for the starter clutch springs and pins to go bad on the old twins......Llarry
Offline 34barab
« Reply #4 on: December 23, 2018, 06:36:05 AM »
No plugs and no gas.  I was using the starter to oil-prime the engine when I first heard the chirp noise.  (Is this sufficient to oil-prime the engine or should I add oil to the top end?)  The chirp sounds like metal on metal or metal on rubber.  Replaced the starter clutch springs, caps, and rollers during the rebuild.  No contact marks on the inside of the alternator cover.  You get the same noise kicking it over, and the chirp seems to occur at a particular point of the four-stroke cycle; but it's hard to determine precisely which point.  (I don't have a pressure gauge).  One thought I had: Even though the chirp seems to be coming from the left side, is it possible that one of the two small Cam Chain Roller Pin Rubbers that help hold down the Cam Chain Roller Pin got cockeyed or fell into the crankcase, causing the Cam Chain Roller to rotate at an angle?
Offline 34barab
« Reply #5 on: December 23, 2018, 06:51:50 AM »
Sorry, robvangulik.  1972.
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: December 23, 2018, 07:53:22 AM »
This is a 2-cylinder, correct?
Offline MoMo
« Reply #7 on: December 23, 2018, 08:16:21 AM »
possibility.  did you replace the lower roller and guide.  Most everyone I've seen was toast....Larry
« Reply #8 on: December 23, 2018, 09:56:06 AM »
Is the compression blowing out the gasket, a lot of pattern gaskets for that model are real #$%*e
Offline 34barab
« Reply #9 on: December 23, 2018, 01:29:57 PM »
Yes, two cylinder.  Replaced the entire cam chain tensioner assembly with NOS components, and all the gaskets with a kit from Common Motor Collective.  How can I check to see if the compression is blowing out the gasket?  (Head gasket or one between crankcase and cylinders?)
Offline innovativems
    • Innovative MotoSports
« Reply #10 on: December 23, 2018, 03:20:55 PM »
Is the sound coming from the stator cover?   Could be the starter clutch making noise as it turns over
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline 34barab
« Reply #11 on: December 23, 2018, 04:23:30 PM »
Link below is short video of the issue.  the chirp could be coming from the points.  I did lube the points cam.
https://photos.app.goo.gl/4unxVuWPnJgaqgRj6
John
Offline 02z06dave
« Reply #12 on: December 23, 2018, 07:14:01 PM »
Ive heard a noise like that twice before. Once the oil seal behind the points plate had been put in slightly cocked and the cam was rubbing it weird. The other time, it was a rubber intake manifold and that chirping noise was air getting sucked into a little crack in the rubber
« Reply #13 on: December 25, 2018, 09:52:50 PM »
 They all sound to me like they're flying apart. Especially when there's no exhaust or combustion.
Offline MoMo
« Reply #14 on: December 25, 2018, 11:28:40 PM »
That is one fairly accurate observation Don,  the old twin is one noisy motor.  Hope you had a great Christmas...Larry
Offline tbpmusic
« Reply #15 on: December 26, 2018, 08:20:27 AM »
The alternator runs oilfree ...................
That's not the case, there is oil in there, just take the round cover off while it's running (like to use a timing strobe), and you'll get a facial (so will your timing light - put saran wrap over it).
Bill Lane
Offline robvangulik
  • Honda Fourever
« Reply #16 on: December 28, 2018, 11:16:43 AM »
That was my (wrong) assumption for it to be a 350four, before this thread was moved to "other bikes".....
