Author Topic: Crankshaft Problems CB750  (Read 3496 times)
Offline Jens77
Re: Crankshaft Problems CB750
« Reply #25 on: December 28, 2018, 01:26:02 AM »
Bad News...i checked again...23,13 is in the base.
You can see where the crankshaft worked, its only 22,75
So what to do now?
Its the service limit...any experience?
« Last Edit: December 28, 2018, 01:27:39 AM by Jens77 »
Offline Tracksnblades1
« Reply #26 on: December 28, 2018, 08:35:27 PM »
Excellent pictures... You know what they say about a picture's worth.
If I read 754 last post, I think someone My have already tossed the old crank.
You may be looking at the old cranks wear marks. I think it is what was trying to do the welding.
Does the crank you removed have matching wear marks...?
Age Quod Agis
Offline Jens77
« Reply #27 on: December 28, 2018, 11:46:17 PM »
Yes...you can see it in the crankshaft, looks little like polished
« Reply #28 on: December 29, 2018, 01:35:54 PM »
It's strange.
 It does not look deep so may not be a  problem , work the high spots off.
 One thing comes to  mind.. maybe.  . Bike went down on alternator side breaking cover,  kept running pushing the crank against the thrust surface ? .
« Reply #29 on: December 29, 2018, 03:48:13 PM »
If it is still in spec use it
Offline Jens77
« Reply #30 on: December 31, 2018, 07:53:53 AM »
I dont know about the history of this bike.
Everything might be possible.
Some say the case is rubbish.
I am not sure, its not too deep...but on the service limit.
Hmmm...i remouved the material carefully.
Have to check crankshaft and rods.
Then i will use it again..i did not get a new on Christmas 😣
Anybody tried washer on legt and right side or other way of guiding the crankshaft?
Happy 2019
« Reply #31 on: December 31, 2018, 10:13:23 AM »
DO NOT put anything on end of crank.
« Reply #32 on: December 31, 2018, 10:44:17 AM »
What is your end play ( thrust ) clearance....?
Age Quod Agis
« Reply #33 on: December 31, 2018, 11:32:02 AM »
I finally found Honda's production min, max, and service limit in the same publication.
Hope this helps with your decision. Have a Happy New Year.....Hic-cup...Hic-cup...burp......hic-cup
Toot......🎉😎
Age Quod Agis
