Author Topic: 500T Tank , can I use it as a "strap on"  (Read 3167 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« on: January 20, 2007, 03:17:37 PM »
will the 500T tank strap right onto a 500/550/4?? ???
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Re: 500T Tank , can I use it as a "strap on"
« Reply #1 on: January 20, 2007, 04:21:51 PM »
I'll check. They are sitting side by side in the shop.
Fonda Honda
wesniles
« Reply #2 on: January 20, 2007, 04:29:34 PM »
i tried to use a 75 500t tank on my 76 550f but there seemed to be a problem with the rubber mounts in the front sticking out too far for it to fit.  Also i noticed that the petcock was hitting my carb and holding the rear of the tank up a little high.
Offline puppytrax
« Reply #3 on: January 20, 2007, 05:49:20 PM »
i tried to use a 75 500t tank on my 76 550f...
It was mentioned in another thread that the 550F and 550K tanks mounted differently...
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #4 on: January 20, 2007, 07:53:33 PM »
for clarification a 500T on  to a 500\4.
SOHC Member#4000
78' 550
73' CL175
Offline keiths
« Reply #5 on: January 20, 2007, 08:10:10 PM »
Here's the last time this question was asked.
http://www.sohc4.us/forums/index.php?topic=8968.msg83045#msg83045
Offline keiths
« Reply #6 on: January 20, 2007, 08:13:25 PM »
Here's the original question with pic's.
http://www.sohc4.us/forums/index.php?topic=8189.msg75759
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #7 on: January 21, 2007, 05:45:06 AM »
thanks,
some good info there, but it does not address the 500T to 500/4K  "clean" swap.  unless i misread it..
SOHC Member#4000
78' 550
73' CL175
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #8 on: January 21, 2007, 09:17:34 AM »
     chippy,   I'm not sure about the shape of the underside of the 500T tank. I don't have a 500T tank to check it on a 500 but, I do have a 450 tank and they should be the same underneath and only being different in the actual outward shape of the tank. If you want, I will check that when I get a chance.
        Later on, Bill
Member # 1969
Offline keiths
« Reply #9 on: January 21, 2007, 09:33:01 AM »
I have a 500T tank and can give you any measurements you need. I would think that the most important would be the distance needed to clear the coils.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #10 on: January 21, 2007, 10:01:47 AM »
I believe ANY tank can fit on ANY bike , if the time and effort is spent.
Moving the front mounting rubbers is not a big task, alittle banging to make room for coils underneath, etc..
CHIPPY, Whats wrong with the tank you have ?
Offline bill440cars
« Reply #11 on: January 21, 2007, 10:32:50 AM »
        Let's see, "Will the 500T tank strap right onto a 500/550/4??  ???" I'm not sure BUT, I think chippy would like a different style of tank. And he might want one that wouldn't take much to install it. That seems to be the direction he's going and the 500T tank seems to be a popular item with some, and that's cool. 8)
                                                          Later on, Bill :) ;)
« Last Edit: January 21, 2007, 10:39:37 AM by bill440cars »
Member # 1969
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #12 on: January 21, 2007, 10:48:37 AM »
I know anything can fit anything, as babyfood1217 has so poignantly illustrated(see pic).
I just like the 500T tank, AND i am unmotivated and don't want to "chop" or "modify" anything, just wondered if it would seat right up "clean swap" per se.
SOHC Member#4000
78' 550
73' CL175
Offline keiths
« Reply #13 on: January 21, 2007, 11:13:59 AM »
"clean swap" No!
Offline grumburg
« Reply #14 on: January 21, 2007, 05:02:58 PM »
Checked today. Agree with Wesniles.
Fonda Honda
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #15 on: January 22, 2007, 05:20:57 AM »
so what you saying is....NO. ::)
thanks for all the effort fellas!!!!
SOHC Member#4000
78' 550
73' CL175
Offline jrrobertsjr
  • If you aren't scared, your not going fast enough.
« Reply #16 on: January 22, 2007, 12:41:39 PM »
OK.. I have nothing to add except that is the worst mental image I have ever gotten from a subject line.
