Author Topic: unleaded fuel  (Read 4212 times)
Offline Bazzer
unleaded fuel
« on: December 27, 2018, 11:27:05 AM »
Do the 750A's run ok on unleaded, i have a 1978 model.the owners manual says non lead gasoline is not recomended. I live in the UK and the bike is not registered here yet , i have only had it running in the shed. Any thoughts would be good.
Offline Old Moe Toe
Re: unleaded fuel
« Reply #1 on: December 27, 2018, 04:58:49 PM »
Can't you get a hold of the additive that comes in a small container that you put in with the unleaded fuel when you fill up. I use it for my older bikes.
Re: unleaded fuel
« Reply #2 on: December 27, 2018, 07:17:14 PM »
They all will run on unleaded
Offline Bazzer
Re: unleaded fuel
« Reply #3 on: December 29, 2018, 01:57:57 PM »
I have that additive that is added to the fuel, I just wanted to know how people get on using unleaded fuel . for example , do their exhaust down pipes go blue, ( very unusual for a honda ) indicating running too hot.
Offline jukku
  • Happy with my Hondamatic
Re: unleaded fuel
« Reply #4 on: December 30, 2018, 07:59:50 AM »
All Honda bikes, as standard since 1972, run on unleaded fuel 95 octan RON!
Re: unleaded fuel
« Reply #5 on: December 30, 2018, 07:52:42 PM »
The valve guides in the 750A (and all these bikes) are cast iron. This wears with the lack of lead in the fuel. To counter it, use 1-2 ounces of oil in each tank of gas. If you can find the synthetic type of 2-stroke oil for this, it will not smoke, either (that's what I've used for a LONG time). This will extend the life of the valve guides for nearly original life. If you go into the engine, get bronze guides installed to solve this problem, it works fine.
Offline Marks78
Re: unleaded fuel
« Reply #6 on: January 02, 2019, 07:57:20 AM »
So -- instead of adding 2 stroke or regular oil to the fuel, could a person use a product like a ZDDP additive (added to the oil) and get the same benefits??
Current Stable:
1978 CB750K
1982 XT200J
1982 XJ1100 Maxim
1985 V30 Magna
1998 VT1100 Spirit
2006 GoldWing
Re: unleaded fuel
« Reply #7 on: January 02, 2019, 05:19:16 PM »
That only works for the intake valve. The exhaust valves rely entirely on lube in the exhaust gases (which used to be hot lead) and the 2-stroke oils do not fully burn when used in these engines. In some places you can get "upper cylinder lubricant" (aka 'top oil') that goes into the gas, but in the USA this was banned by the liberals in 2002. So, we use real oil instead.
Offline Maraakate
Re: unleaded fuel
« Reply #8 on: August 14, 2020, 07:10:40 PM »
Old thread, but are you referring to the Lucas Upper Cylinder Lubricant?  You can still buy that in the US.
1977 CB550K
1979 CM400A
Offline Randy Nevrotski
  • Randy
  • ITS AUTO-MAD-TIC
Re: unleaded fuel
« Reply #9 on: August 26, 2020, 08:23:25 PM »
what about mastery oil
1976 CB750A & Other bikes 1980 KZ 650 cafe racer  81 CM400A 82 GS450 79 KZ650 84 NIGHTHAWK 700 77 KZ650 CAFE  87 ZX750R NINJA 2001 KATANA 600 1983 GPz 750 1980 CB750 CUSTOM Past bikes 1974 suzuki GT750 TRIPLE Care Free Custom chopper 117 motor 95 Honda XR650L Dual Sport 87 ZX600R NINJA Honda CB550FOUR 87 Yamaha 225 trike honda 250R trike RM80 HONDA TRAIL CT70
Re: unleaded fuel
« Reply #10 on: September 11, 2020, 06:14:22 PM »
If you're referring to Marvel Mystery Oil: that is a highly-detergent oil used to remove deposits on valve faces and piston crowns in a hot engine. It works well for that, but doesn't lube the valve stems very well when running.
Just add a little 'normal' or 2-stroke oil to the fuel in the tank: that works well. Modern 2-stroke oil doesn't smoke much, either.
