Author Topic: Sprokets and ratio  (Read 1760 times)
cub
Sprokets and ratio
« on: June 07, 2005, 01:17:47 AM »
I'm thinking of buying a new chain and sprokets and have a question that noone I've spoken to have an answer to. Perhaps you guys know.
If I keep the same ratio e.g. 2,00 (easier to count with) does it make any difference if I use 16/32, 17/34 or 18/36? Does the sizes on the sprockets matter at all if the ratio is the same? I was thinking that maybe it does some difference comparing the sprocket size and the wheel size? And if so, what is the difference between smaller vs bigger?
Offline dusterdude
Re: Sprokets and ratio
« Reply #1 on: June 07, 2005, 05:11:37 AM »
no diff between countershaft and/or rear sprockets
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Robert
  • Sorry for my English
« Reply #2 on: June 07, 2005, 06:20:45 AM »
Well, to keep with the example you used, the 16/32 will wear out faster than the 18/36 combination.
Maybe there are other side effects in chain movement/stressing I can't say. Propably relevant for racing only.
