Author Topic: I have a problem. Need help  (Read 858 times)
Offline alanwaker
« on: January 03, 2019, 11:48:12 PM »
Hi i bought a dynatek DS 1-2 for my Honda cb 750 f2 1978 mod. When installing i have a problem. When i connect a 12v test light from the junction of the blue or yellow coil wire i got constant light. It seems like the power to the coil go right tru the ignition coil and out to the dyna s. Is it nessesary to change the ignition coils?
Offline 540nova
Re: I have a problem. Need help
« Reply #1 on: January 04, 2019, 02:41:26 AM »
If it's similar to a Charlie's Place,  your light may stay on until you approach the F mark, where it will go dim or out, then on full bright at the F, if it's adjusted correctly.
Sent from my SM-G955U using Tapatalk
« Reply #2 on: January 04, 2019, 03:04:59 AM »
read the instructions,contact dynatek?
