Author Topic: Any good tricks for restoring the front brake disk on a CB750?  (Read 8907 times)
Offline markb
  • When I finish my current project I might be a
« on: January 07, 2019, 05:35:30 AM »
I have a disk in nice shape but would like to improve the looks of the disk itself. I can chuck it on the lathe on the ID and I'm thinking maybe Scotchbrite or fine sandpaper. Any opinions before I try it?
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline 69cb750
Re: Any good tricks for restoring the front brake disk on a CB750?
« Reply #1 on: January 07, 2019, 05:41:34 AM »
You can block sand on bench or on wheel, lathe not needed.
Offline markb
« Reply #2 on: January 07, 2019, 05:46:08 AM »
True, but I figured the rotary motion would make a more uniform pattern.
http://forums.sohc4.net/index.php/topic,175236.msg2043166.html#msg2043166
That is a good looking disk. Do you know where True Disk is located?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: January 07, 2019, 08:47:10 AM »
True Disk is the bomb, great work.
So far no squealing either.
And after you get it back you do this.
I used paint remover, wire brushes, elbow grease, patience.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline sixthwisconsin
« Reply #4 on: January 07, 2019, 10:08:18 AM »
True Disk looks like they do great work. I notice from their web site that they will not thin the rotors beyond OEM spec. (6mm in our case)
I am running several bikes with Godffreys drilled & thinned (4mm) rotors and have not heard of any issues with them.
https://godfferysgarage.com
Good to have options.
Offline markb
« Reply #5 on: January 07, 2019, 10:35:53 AM »
Those all look good but I don't think it matches the original grind pattern. This would be for my sandcasts so I looking for something closer to original. These others have more of a circular or swirl pattern similar to what you would get from a Blanchard grinder.
« Reply #6 on: January 07, 2019, 11:54:38 AM »
Does anyone really know what these discs looked like before they were ever used?  50 miles of use is gonna establish a pattern that will stay forever.
Offline markb
« Reply #7 on: January 07, 2019, 11:57:33 AM »
Sorry, I guess I should have been more specific in my first post. I wasn't trying to be argumentative. I asked for opinions and I appreciate all that I got.
TrueDisk does Blanchard grind, for a reason.
Just curious, what is the reason?
« Last Edit: January 07, 2019, 12:08:48 PM by markb »
Offline markb
« Reply #8 on: January 07, 2019, 12:08:26 PM »
Here’s what they looked like. I actually have a NOS K1 rotor (the hub is different on the earlier ones). The rivet idea might not be a bad way to go.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: January 07, 2019, 02:44:27 PM »
I totally agree about Blanchard vs. circular grind pattern. If absolute stock is what is called for, such as a very low number restoration, put the disc in a lathe or similar tool to put a circular pattern on it. In my case, I wanted them drilled so totally stock is not in the decision. I’m very happy with how they work, very light feel, no squeal (at least not yet), very predictable and progressive. Of course the dual discs feel a lot different than a single.
I have no scientific data but I wonder if the Blanchard grind makes the feel better. I sure like them.
1973 CB 750 K3
« Reply #10 on: January 07, 2019, 04:25:54 PM »
 I will post more info later re original finish..
 But really sanding block on a lathe looks pretty close. And Blanchard does not .l
« Reply #11 on: January 07, 2019, 05:16:40 PM »
Also, the stainless is too hard to be easily cut...thus the grinder.
Thanks Mark for the posted pic.  I can't imagine I will ever see a NOS rotor anywhere else.
« Reply #12 on: January 07, 2019, 08:16:37 PM »
 A few things, they are hard to surface or thin on a lathe due to resonance  or ringing or vibration.
 And while Blanchard grinding is efficient and fast,  it will never look stock  and that is a problem when you  restore a high end  bike, you need the right finish.
 Which I tried to set up for.. but I had to close down the shop.
 But I am  trying to setup a smaller place.
 And still have the grinding machine, and a very Skookum rotary table that we were trying to set up a drive  for... but nothing in the immediate future.
So basically picture a record player , the disc  is the record, the needle is a surface grinding wheel, it needs to grind say a thou or two per cut, and feed across the disc surface.. then it will look stock.
And I had the grinder working, the grindstone did a nice job on stainless, but I was turning a rotary table by hand, and feeding out... long enough to see that it could work... but it needs  a motorized drive.
 I hand cranked to see if it could work and I had the right stones to prove the concept.. but the tryout gave me tendonitis.
« Last Edit: January 07, 2019, 08:42:23 PM by 754 »
« Reply #13 on: January 07, 2019, 09:04:55 PM »
I've spun them in a lathe and used 150 grit emery cloth on a rubber sanding block. This won't remove much material no matter how long you do it, so any deep grooves won't clean up, but it might be closer to the finish Mark is looking for. Pics are a bit fuzzy..
Offline markb
« Reply #14 on: January 08, 2019, 05:26:51 AM »
I think I will give this a try. I have plenty of disks to experiment with. Thanks everyone for all the great info.
Offline markb
« Reply #15 on: February 19, 2019, 02:38:48 PM »
Anyone know what the minimum thickness of the disk should be?
« Reply #16 on: February 19, 2019, 07:14:27 PM »
6mm. Out of curiosity, I just measured mine and it was over 7...
« Reply #17 on: February 19, 2019, 08:16:35 PM »
I thought it was 6.5mm? It's marked on the hub.
Offline Tom C
« Reply #18 on: February 21, 2019, 05:10:14 PM »
Here is the disc from my 72 CB350 four with 6800 miles before I sent it off to https://truedisk.net/:
And here it is afterwards:
Very happy with the results!
Hooray!  My first post on SOHC/4!
74 CB550K0
« Reply #19 on: February 21, 2019, 06:45:09 PM »
That is really nice!!
I would like to ask for opinions as to thinning these beyond the 6mm min spec. Most modern disks are around 4mm+- and other offerings on this forum are thinned to 4mm as well as drilled. They are much lighter and I personally have run them with no issues but not in a racing or high use environment. Very curious as to the opinions here on thinning these beyond 6mm Honda spec of the day.
« Reply #20 on: February 21, 2019, 07:03:19 PM »
The 6mm spec is wayyy overbuilt...certainly does not need to be that thick.  These rotors are virtually indestructable.  I had mine thinned by Goddfrey's Garage.  I believe he takes them down to 4mm.  Goddfrey's drilling pattern is much more period looking imo also and a lot more holes.  All this has been used for several thousand miles of hard use on Michigan back roads on my F0.  Why not support a forum member and get same or better service?
« Reply #21 on: February 22, 2019, 02:58:47 AM »
More holes aren’t necessary, and TrueDisk Blanchard grinds their disks. Not sure how Jeff thins his. But, Tom provides an outstanding service, why not also support him?
Godfrey s are also Blanchard ground.  More holes equals less weight.   He is a site supporter and regularly contributes to this forum.
I think I will continue to use goddfrey's.
« Reply #22 on: February 22, 2019, 05:03:25 AM »
  Goddfrey's drilling pattern is much more period looking...
What period? Not SOHC.  Personally, I don't like the look of drilled rotors on my vintage bikes.   When were they first used, late 70's?
« Reply #23 on: February 22, 2019, 09:36:46 AM »
Jesus ducking christ!..?  Try to encourage support of a forum member and what do you get?
Cal, why don't ya pm Godfrey and ask him ...kinda nice how being a forum member works like that.
Steveo, check my quote...pretty sure I said MORE period correct...as in closer to...and i am perfectly happy to leave my rotors as is too.  These are not gonna warp, groove deeply, break or bend unless you run over them with a Mack truck.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #24 on: February 22, 2019, 11:06:23 AM »
The Godffrey thinned and drilled front disk on my 550F held up great hauling my ~240lbs plus gear up and down the Colorado mountains and the 300 turns on the Coronado Parkway in Arizona. So I would also agree that the thinner rotor isn't an issue. He also installed new stainless nuts and bolts for the disk to the center hat and offers a service to counter sink the bolt heads to make fitting up a 2nd front disk easier.
Since he is relatively local to me (about 90 miles) I picked it up in person from him and got a tour of his shop (he contracts out the actual surfacing to a local machinist).
