Author Topic: cafe seat foam  (Read 16622 times)
2valve
cafe seat foam
« on: January 21, 2007, 06:33:58 AM »
Hi,new to the site,really enjoy all the knowledge from the group.
i have a 78 & 71 750,i'm cafeing the rough 71,my question is what type
of foam i should use to form the seat before i cover it .
I'll be using stock pan & want the rear hump cafe style.
USN20
Re: cafe seat foam
« Reply #1 on: January 21, 2007, 06:53:57 AM »
Take a look at this seat foam selection guide: http://www.homestead.com/prosites-rmcycle/foam.html
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: cafe seat foam
« Reply #2 on: July 08, 2009, 02:00:55 PM »
try cutting down a kids  kickboard.
you can get 'em real cheap and their water proof
Offline UnCrash
  • Pass
    • My Blog
Re: cafe seat foam
« Reply #3 on: July 08, 2009, 05:55:30 PM »
Yo IC,
You crack me up!  Your service to long departed never active members is impressive.
Thanks for resurrecting this thread  :D :D :D :D :D :D :D :D :D :D
  • Like a well oiled
    • Undead Asphalt
Re: cafe seat foam
« Reply #4 on: July 08, 2009, 05:59:53 PM »
HAHA, yup!!
I've heard the question from a lot of members.
   I thought I'd post up, what I thought was a good idea.
I'm full of useful information for people that aren't paying attention ;D ;D ;D
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
Re: cafe seat foam
« Reply #5 on: July 08, 2009, 06:39:53 PM »
Damn! I'm paying attention  :D
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
  • Like a well oiled
    • Undead Asphalt
Re: cafe seat foam
« Reply #6 on: August 16, 2009, 07:31:03 PM »
another resurrection for this one
the PERFECT stuff, a golds gym exercise mat, 15 bucks at walmart.
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: cafe seat foam
« Reply #7 on: August 16, 2009, 08:58:11 PM »
i used to be big time into horses till one broke my neck 2 years ago, i'm using this on my cafe seat. when i got it i only paid 24.95  http://www.cashelcompany.com/ProductDetails.aspx?C=2&SC=13&ProductID=8864
Mark Twain - Notebook, 1894
Offline d3buttz
  • More than just an
Re: cafe seat foam
« Reply #8 on: August 17, 2009, 06:35:55 AM »
carpet pad worked out great! carpet stores gave away small 4'x4' for free to me, plus you can layer it for +/- padding! cheap bastards unite!
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
Re: cafe seat foam
« Reply #9 on: August 18, 2009, 03:56:55 PM »
I bought some microcell foam. Like foam on a kyak seat. Water proof so if you dont cover in its ok, ala superbike seat. Feels like memory foam, not too bad, I have 1" on mine & you can get it thicker or thinner.
jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
Re: cafe seat foam
« Reply #10 on: August 18, 2009, 04:51:49 PM »
I have been looking around for the same thing and found that HYDRO-TURF sell 1inch thick foam padding for jetskis. I think it was 39 " x " 19 x 1" for 20 bucks.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline spdiii
Re: cafe seat foam
« Reply #11 on: August 23, 2009, 07:54:46 AM »
I use sectional floor mats. Four 2'x2' sheets at Harbor Freight for around $8.00. It can be layered using contact cement If you prefer more padding and is easily shaped with a razor blade, wood rasp and rough sandpaper.
Nick
'73 CB500
'73 CB500 Cafe
'74 CB550
'74 CB360 Bobber
'75 CL360
'76 CJ360 in progress
'99 Speed Triple
Bay City, MI
  • Be careful you might get a
Re: cafe seat foam
« Reply #12 on: August 23, 2009, 08:14:43 AM »
I thought this was an interesting read.
http://www.rickmayercycle.com/foam.html
Offline SUELZER
  • Active
Re: cafe seat foam
« Reply #13 on: August 28, 2009, 07:08:22 AM »
found this on another SOHC thread (yes 2 discussions on the same topic), thought i'd post it over here as well
http://www.foamandupholstery.com/Open_Cell_Foam.htm
nothing that looks dense enough tho... 3 lb styrofoam but i dont think thats the poly in the bodyboards.
Sounds like i want DOW 300
The link that Hinz posted has a section for motorcycle seat foam, it's located under high density foam.
it's almost at the bottom of the page Multi/Rebounded-Mixed Foam
Common uses: restaurant seats, motorcycle seats, gymnastic and karate mats.
We can offer you custom blocks to do your own carving - custom cutting is available.
1976 Honda 550F
1993 Ducati 900ss
1979 Honda 750F
Veemo
Re: cafe seat foam
« Reply #14 on: June 27, 2010, 11:37:48 AM »
Well I was kind of thinking about buying and cutting up one of those ubiquitous blue foam sleeping pads. I think they're about $6 at walmart, 3/4" thick, waterproof and pretty tough. They come pretty big, so you should be able to cut and layer them to make it thicker if you want, hell you could probably make 2 or 3 seat pads with just one of them. Just thought I'd mention it. I want to make a nice aluminum (polished or painted black? ....hmmmm) cafe seat for my new $25 "Ikea" CB550K once it's running and i was planning on using the blue foam pad.
Offline lowflyingdutchman
Re: cafe seat foam
« Reply #15 on: June 27, 2010, 07:12:14 PM »
Borrowed some from the heating / ac contractor on one of the construction sites I walk around on. Thick foamy stuff that has a smooth surface used to insulate heating and ac piping in big buildings. They wrap the pipes with this stuff. Works pretty well other than that you'll have a print of your favorite jeans in negative in your seat for a couple of days. For some reason doesnt really restore very quickly, but hey. Stuff was free.. :) They will cut the sheets to size and throw away the leftovers. These are big enough to cover ten cafe seats with and they dont mind some diy gearhead to haul off their garbage.
May the Fours be with you.
74CBcafeGR
Re: cafe seat foam
« Reply #16 on: July 01, 2010, 11:02:43 AM »
someone suggested that i use high density foam from a fabric store. i got some 3" scrap for a dollar, brought it home and put it on my regular seat and sat on my bike. it compressed all the way and was pretty useless.
I'm going to try the exercize mat idea. good thinking.
  • Mad Fabricator
Re: cafe seat foam
« Reply #17 on: July 13, 2010, 10:18:28 AM »
I ended up using the 1" pad from hydroturf
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
  • Mad Fabricator
Re: cafe seat foam
« Reply #18 on: July 14, 2010, 06:48:47 AM »
here is the link to the stuff I used. I used the 25 mm pad but they say it is out of stock. I cuts pretty easy but gets a lil rough when you sand it so you probaly want to make a cover for it.
http://hydroturf.com/products/Sheets_of_Hydro-Turf/Underpad
I still havent covered mine but I think it turned out ok.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
