Author Topic: 1976 CB750A starter switch replacement  (Read 501 times)
Offline econguy48
« on: January 09, 2019, 12:55:56 PM »
Hello all
I am trying to replace the starter switch on my 1976 CB750A hondamatic. The bike is low mileage (just over 10,000 miles) but the starter switch gave out (turned to mush inside). I bought a replacement switch #35130-377-P00 which has 5 wires instead of the 6 in the original. Instead of the the green ground wire and the green/red that goes to the starter relay, there is only one yellow/red wire coming from the new switch. I'm not certain as to how to go about hooking this to the starter relay. Can this switch work without the green ground wire. Any help or comments would be appreciated. Thanks.
Econguy48
PS was told that this switch would work on the CB750A
« Last Edit: January 15, 2019, 05:59:40 PM by econguy48 »
