Author Topic: CB550 Brake Drum Bearing Sleeve  (Read 663 times)
Offline 58webbing
« on: January 11, 2019, 03:55:31 AM »
A few minutes ago I was knocking out the rear wheel bearings on my 74 CB550 and I noticed inside the brake drum surrounding the bearing was a steel sleeve obviously put there to support the cast ally hub outside of the bearing housing.
Thinking this was a mod or repair executed by a previous owner I started to run through my repertoire of profanities as I thought this might be a bodge!
After studying some rather blurry pictures on the web it looks like this might be standard from the factory.
My question is this. Is this sleeve standard from the factory? I attach a photo.
« Last Edit: January 11, 2019, 03:57:08 AM by 58webbing »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=e8g9pfa3isurtc56gch3b0li52&/topic,60973.0.html
Re: CB550 Brake Drum Bearing Sleeve
« Reply #1 on: January 11, 2019, 05:04:12 AM »
its standart..but have seen some vitaut...can be from erly 550 vho used 500 hubs
i hate all this v-w.... vords
Offline RustyF
« Reply #2 on: January 12, 2019, 04:38:39 AM »
The rear drum on my 78 looks the same.  Don't worry about it.
1978 CB 550 K
Offline 58webbing
« Reply #3 on: January 12, 2019, 05:16:32 AM »
Many thanks for replying. I will now be able to sleep at night.
