The F2/3 had a "cooler" of a finned plate that was mounted between the filter housing (and filter) and the engine, ostensibly to "cool the oil" (it didn't, really...). The extra-long oil filter bolt then made the whole thing really finnicky to try to reassemble: the PO maybe got mad and hit it with a wrench in frustration? (I'd never do that... ).
But, you can probably use this to your advantage. If you have the cooler plate (or if I have one around here) you can get some of that sticky-back sandpaper that goes on those surface-sander power tools at Ace Hardware, stick some to the back of the cooler plate, then install the cooler plate using the oil filter bolt to align it, and spin it back-and-forth for a perfectly flat sanded surface. If the gouges are too deep for that, I'd go the thin JB Weld route (with super-cleaning first) and then sand IT down to fit.
They don't call me "shade tree wrench" for nuthin'...
