Author Topic: CB550 Starter Motor Cover Gasket  (Read 533 times)
Offline 58webbing
« on: January 14, 2019, 05:07:46 AM »
If anyone, like me, has found the starter motor cover gasket supplied in aftermarket gasket sets is too big and the wrong shape here is a DXF file for those of you with access to a laser cutter. I made mine out of high density polyurethane foam 3mm thick.
