Author Topic: 1/4 Coil Blue Wire Crackling?  (Read 547 times)
Offline Snoefy
« on: January 19, 2019, 11:25:49 AM »
CB500K 1972 had both #1 and #4 not firing. Checked valves and cam chain, assuming compression is good now.
Took the tank off and tested spark, found no spark in both #1 and #4, jiggling the wires around on the coil checking them out I hear a lite but distinct crackling, I believe it’s from the blue wire. Not sure how to proceed or what steps to take.
After juggling the wires to make sure they were on he coils I did get spark back in both #1 and #4
1971 Red CB500K "Rhonda"
Offline pjlogue
Re: 1/4 Coil Blue Wire Crackling?
« Reply #1 on: January 19, 2019, 05:15:53 PM »
Check for arcs from the high tension leads in the dark.  The plug wired may be grounding up by the coil.  A small crack in the insulation or the plastic coil housing can ground out the coil preventing the spark at the plug.
-P.
« Reply #2 on: January 20, 2019, 05:10:43 AM »
The blue wire runs from the coil to a connector in the rubber boot by the rear brake pedal so you can easily run a temporary bypass wire to check for problems.
Offline Snoefy
« Reply #3 on: January 22, 2019, 06:11:54 AM »
Thank you for the replies - looked like the wire was grounding.
