Author Topic: Does some one know the test spec on accel coils? For SOHC 750  (Read 1560 times)
Offline Gregorymoto
  • SOHC Aficionado
I have a set I tested I’m getting 25OMS on 1,4 lead post and 24OMS on 2,3 lead post.
This measurement is taken with out lead wire.
I looked on line cant find the test spec on them.
If ya can help thanks.
O been gone for 7 months, the new sight is looking good Glen.
Thanks Gregory N. Mountain
Yep, i have issues with this sort of stuff.
Mikeshonda750F
Re: Does some one know the test spec on accel coils? For SOHC 750
« Reply #1 on: June 07, 2005, 07:17:57 PM »
I really wouldnt worry about it too much. Your getting a close reading on each set so all should be well. Are you sure the range on the meter isnt in the "K" range which would give you 2.5ohms?.. which would translate into roughly a 50ish KV burn. If your concerned with the duration and magnitude of the spark, get ahold of an unductive KV meter or have your local mechanic buddy throw it on an o-scope and watch the waveforms of each cylinder, this will directly translate into secondary ignition windings and also give you an idea of how efficent the combustion process is.
« Last Edit: June 07, 2005, 07:19:50 PM by Mikeshonda750F »
