Author Topic: Bearing shells for ally rods  (Read 1263 times)
Offline teebee67
« on: January 29, 2019, 07:10:24 am »
Hi, Does anybody know who can supply drilled big end shells to suite ally rods. I have some Yoshimura rods and some Russ Collins stroker rods that need big end shells. Also can anyone tell me why the ally rods need the location pegs that make these shells with holes in necessary. (I have also had a set of Golden rods that required these).
I'm only old on the outside.
Re: Bearing shells for ally rods
« Reply #1 on: January 29, 2019, 08:57:12 am »
 There was obviously some concern with the shells spinning in the rods. You may have to make a jig and drill your own.
If you love it, set it free, if it stays it's probably one of my 750's.
Offline teebee67
« Reply #2 on: January 30, 2019, 02:34:44 am »
Thanks Don, I am surprised at that because they still use the locating tangs. But there must be a reason for it and yours sounds logical. My problem is it's a Yoshimura lightened crank (so no markings) and yoshimura rods (again no marking) so I need to try different size shells and plastigauge them to find the correct shells.
« Reply #3 on: January 31, 2019, 08:54:16 am »
I can do that for you.
Offline teebee67
« Reply #4 on: February 01, 2019, 03:26:20 am »
Thank you for your kind offer, pm sent.
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #5 on: February 03, 2019, 10:36:57 am »
Yes.  Aftermarket aluminum rods are fitted with a dowel pin in the cap to be used with a drilled lower bearing. Spun bearings would happen on every pass without it, likely due to the growth of aluminum but the elasticity benefit it provides is worth it.
Due to large volume on the automotive racing end, lower bearings shells can be purchased off-the-rack pre-drilled and coated.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
