Author Topic: Suzuki GT 550  (Read 959 times)
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
Suzuki GT 550
« on: January 30, 2019, 05:21:29 PM »
So I haven't been on here in YEARS... But this forum is probably a better resource for Suzuki than the Suzuki forums. Some one has done this....  1973 Suzuki GT 550... On the right side engine is points plates with 3 sets of points. So I'm attempting to set timing.  The problem is each of the 3 points fire while the relative piston is on bottom of stroke. (We all know thats not gonna work) The point plate is on correctly.. It occurred to the relative postion of the Cam that opens the points must be wrong. Ultimately I pull the entire right side clutch and point cover to observer how the shaft that drives point cam interfaces crankshaft. The engine pistons would need to be in correct relative position. I assume since left cyclinder is number 1.. I put that at TDC then cam timing woud be right. I'm wrong... Doing that results in spark being delivered while piston is at bottom of stroke. I found instructions on a Suzuki 380 triple on the marks to line this up, but I can't find any instructions on a 550 and it's much different than a 380..
Has anyone done this?
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline Greaser Greg
  • I'm a liquor in the front and poker in the rear
  • Motorcycles needed = # owned +1
Re: Suzuki GT 550
« Reply #1 on: January 30, 2019, 07:13:51 PM »
Had a kz400 where the breaker points cam was on backward. Spark was off 180. Flipped it and all better.
Nothin matters, if ya don't mind.
74 CB550
78 CB750F
71 R5
71 R5 in progress
97 XL1200S
08 XL1200N
78 Hobbit
02 4trax 350
? Chinese 49cc mini rat/lightweight
