Author Topic: Swing Arm Bushings  (Read 1438 times)
Offline steve
Swing Arm Bushings
« on: February 02, 2019, 06:06:19 am »
I am trying to remove the swing arm bushings on a 76 cb550.  These are the plastic ones that have an outside flange.
Does anyone have any tricks?  I have tried this before and broke them.
Offline 540nova
Re: Swing Arm Bushings
« Reply #1 on: February 02, 2019, 06:09:38 am »
Don't worry about breaking them. They should be replaced anyway.
Sent from my Pixel 3 XL using Tapatalk
Offline pjlogue
« Reply #2 on: February 02, 2019, 06:42:42 am »
Try putting a dowel into the swing are bore and pushing them out.  They should come out fairly easily.  What 540nova said, the fiber/phenolic ones don't last long so replacing them is a good idea.
-P.
Offline jtunberg
« Reply #3 on: February 02, 2019, 08:03:39 am »
On bushing removal, I take a washer and shave enough off two sides were it will slip thru the bushing. Once it is inside the swingarm flip it flat against the bushing and press it out.  Hope this helps
John T
« Reply #4 on: February 02, 2019, 10:27:19 am »
I use a long drift punch and a BFH. No problem!
'74 "Big Bang" Honda 750K [836].....'71 Honda 750K project.....'76 Honda 550F.....K3 Park Racer!......and a Bomber!............plus plus plus.........
« Reply #5 on: February 02, 2019, 03:23:39 pm »
Use a hack saw blade. Cut through/mostly through one spot maybe 2 if necessary. Take a screw driver blade etc and get under it and hammer it out in pieces.
« Reply #6 on: February 02, 2019, 07:28:27 pm »
I guess I'll have to add this process to my upcoming 550 book, too?
Offline Fezzler
« Reply #7 on: February 06, 2019, 12:26:36 pm »
This is what I did a few months back.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline Erny
« Reply #8 on: February 06, 2019, 01:09:50 pm »
Absolutely  ;D
One more reason is that I bought last week CB550K1.
So your 750 book is waiting for 550 to arrive asap  8)
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #9 on: February 07, 2019, 06:29:23 am »
Same!
--Evan
1975 CB750K "Rhonda"
Offline sparks1
« Reply #10 on: February 14, 2019, 09:14:55 am »
Hondaman...looking forward to your 550 book also. When is it expected?
 Picking up a CB550 on Sunday. Been out of the mc game for awhile, getting a project for retirement.
Offline Deltarider
  • Another big liar has to face the truth.
« Reply #11 on: February 14, 2019, 12:40:08 pm »
Any idea why mine have done 135.000 km and still don't show any play in spite of having been greased no more than three times in the last 100.000? I mean... I must have done something 'wrong'.  ;)
CB500K2-ED Excel black
« Reply #12 on: February 15, 2019, 02:57:30 am »
You must use a pressure washer!
Recommended to spray a lot of degreaser first on all bearings, then go hard with 130-150 BAR Kärcher or similar!   8) Warm water even better!! ;D
CB750 K6-76 1005cc JMR Billet block.
Offline rotortiller
« Reply #13 on: February 15, 2019, 04:28:40 am »
+1
[I take a washer and shave enough off two sides were it will slip thru the bushing. Once it is inside the swingarm flip it flat against the bushing and press it out. /quote]
