Author Topic: CB550K1 - stuck piston and pad in caliper  (Read 1130 times)
Offline Erny
« on: February 02, 2019, 04:05:13 PM »
Trying to disassemble totally stuck pad and piston from caliper. I'd like to save pad, MC was leaking, did not had power tu push piston, compressed air did not worked too. Now trying to use penetrating oil. Any other  option? Not sure if problem is in the piston or pad or both.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Re: CB550K1 - stuck piston and pad in caliper
« Reply #1 on: February 02, 2019, 04:07:34 PM »
Take a grease gun with flexible pipe and unscrew the nozzle from the end, the pipe will then screw into the pipe fitting on the caliper but only by a couple of threads, pump away and watch the piston come out
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: February 02, 2019, 05:17:05 PM »
Years ago I pulled off an old caliper. Cut the bottom, metal pipe near its’ base and tossed it in a parts bin. A few months ago, decided I needed that one rebuilt. I unscrewed the bit of brake pipe and flair nut. Drilled out the pipe, then tapped the nut to a std. grease nipple. Clipped on my grease gun and the pad and seal pumped out smoothy! Wrap it in a rag to catch the bits, but never any drama! Much safer than comp. air........
Offline Erny
« Reply #3 on: February 02, 2019, 05:28:32 PM »
If you’re trying to save the pad, stop pouring penetrating oil in the caliper. The pad will absorb the oil, and ruin the pad permanently.
Once out, sand the painted edges of the pad so that it slips in and out freely of the caliper.
This is true... Probably too late now
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: February 02, 2019, 07:20:42 PM »
Ummm, that photo is not the hydraulic side of the brake caliper.
Pull the lynchpin above the pad and try again.
Offline rotortiller
« Reply #5 on: February 03, 2019, 12:17:04 AM »
Non hydraulic end pad is worn out as it is at the same level as the caliper machined surface.
Offline johans
    • corporate leather
« Reply #6 on: February 04, 2019, 11:06:59 AM »
+1 on the grease gun ,works great
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
Offline Erny
« Reply #7 on: February 04, 2019, 01:56:42 PM »
No, it IS hydraulic side with pad pressed in in jaw vise. This was the only movement I managed. I'll try next days trick with grease gun, I'm sure it will work!
Let you know result after
Offline Erny
« Reply #8 on: February 06, 2019, 03:27:41 AM »
So, work done, what a great tip using grease gun! Unbelievable easy work! Issue was caused by corroded pad stuck in caliper. Thanks for the tip again!
Btw if not yet there this should be part of tips section
« Reply #9 on: February 06, 2019, 07:46:51 AM »
Grease gun trick is fun!  But a little messy cleanup...
Offline BenelliSEI
  • 1969 cb750
« Reply #10 on: March 28, 2019, 05:24:53 AM »
I’d forgotten about this post. I used the “grease gun trick” a few days ago. Scooped out the old grease with a popsicle stick and lubricated the exposed slides and guides on my old snow plow!
