Author Topic: Quick tire question  (Read 686 times)
Offline AlekStooge
  • can't afford cheap stuff
Quick tire question
« on: February 10, 2019, 05:03:01 pm »
I'm rebuilding my wheels. 1978 CB 550K, stock size rim 1.85 front and rear. I found front tire 3.25/100-19 for the back I could do 100/90-18 or save $20 and do 4.00/100-18. The width difference is minuet, I'm thinking of the aspect ratio should I match it to the front or just save the $?
https://www.denniskirk.com/avon/am26-roadrider-tire.pfp543162.prdf
Thanks
Offline Bankerdanny
  • Endeavor to persevere
Re: Quick tire question
« Reply #1 on: February 10, 2019, 05:53:16 pm »
The 4.00 is too wide. The 750 that tire fits has a 2.15 rear rim. Spend the extra $20 and get the 100/90, it is slightly wider that stock, but will fit the rim fine.
Offline AlekStooge
« Reply #2 on: February 10, 2019, 06:02:48 pm »
It's a 1.6mm difference between the 4.00 and 100? The cost is less for the 100/90...
« Reply #3 on: February 10, 2019, 07:29:52 pm »
I put a 4.00 on my 550F....no issue for me.
'74 "Big Bang" Honda 750K [836].....'71 Honda 750K project.....'76 Honda 550F.....K3 Park Racer!......and a Bomber!............plus plus plus.........
Offline flatlander
« Reply #4 on: February 10, 2019, 11:15:58 pm »
#me too
Offline brewsky
« Reply #5 on: February 11, 2019, 02:33:30 am »
Me 3....'78 550K
Match front and back....either inch or metric for both
3.25-19 and 4.00-18 handle perfectly
« Last Edit: February 11, 2019, 03:21:40 am by brewsky »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #6 on: February 11, 2019, 10:59:40 am »
I've been using 3.25 19 fronts and 4.00 18 rears on my 550s for 30 years.  No regrets. I did try metrics out a while back.  But, went back to inch sizes.
I think the stock rear was 3.75, 18  which isn't easy to find these days.  (Or necessary, imo.)
The inch sizes are more apt to have the aspect ratio profile (100%) that was used in the suspension design, rather than metric sizes which use, at best, a 90% ratio.  But, tire manufacturer do take liberties.
I've been happiest with Metzelers, so far.
