Author Topic: Exhaust Question  (Read 713 times)
Offline Vintageguy
Exhaust Question
« on: February 16, 2019, 12:06:02 PM »
I'm getting my original 4 into 1 exhaust cerecoated as close to chrome as possible. The pipes are off and at the plater, and I intended to replace the exhaust gaskets in all cylinders in the process of re-assembly. I note a slight ridge about 1/32 of an inch in from the rim of the exhaust. I don't think it is the used exhaust gaskets, but could be wrong. Are these crush washers, or do they retain a round shape once installed? These are more or less flat. If they are indeed crush washers, what is the best way to remove them? Thanks to any responders.
Offline flatlander
Re: Exhaust Question
« Reply #1 on: February 16, 2019, 12:50:26 PM »
yes they get crushed flat when installed. it's quite common that some PO "forgets" one of those in the port without realising what it is.
you can use a fine, flat blade screw driver to pick it out.
Offline Johnie
« Reply #2 on: February 16, 2019, 01:58:47 PM »
Or a mechanics pick works excellent too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline flatlander
« Reply #3 on: February 26, 2019, 11:14:50 PM »
so did you get them out, or still poking in those ports?
Offline Vintageguy
« Reply #4 on: February 27, 2019, 05:22:55 AM »
Came out easier than I thought. Used a T-handled spring stretcher with a sharp point. Crushed 'em and pulled 'em right out. Thanks.
Offline flatlander
« Reply #5 on: February 27, 2019, 06:20:57 AM »
nice  :D
