Author Topic: float seat removal 360 t  (Read 1579 times)
Offline mrblasty
  • Expertly
« on: January 22, 2007, 09:37:46 PM »
How do you guys remove the float seat from the CV carbs?  I have one carb that continues to flood despite proper float height and a
decent needle, I suspect there is an o-ring in there that is toast and would like to check it out. the bike in question is a 76 360 t.
Thanks in advance.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline crazypj
  • I'm brill, me
Re: float seat removal 360 t
« Reply #1 on: January 23, 2007, 10:19:36 AM »
Its pressed in with a retainer. You should be able to pull it out after you remove the holding clip. 'O' ring doesn't usuall fail unless carbs have been dipped in carb clean ( good possibility on bike that old)
PJ
Offline mrblasty
  • Expertly
« Reply #2 on: January 23, 2007, 10:48:03 AM »
Yeah I dunked both carbs as a matter of course when i got the bike home. my rt side carb is fine, the left one has been a real pain in the nuts.
Thanks for the reply
1973 Honda CB 750
1975 GL 1000
Offline cb650
« Reply #3 on: January 23, 2007, 01:58:45 PM »
As I've been riding mine for 3 years I should now more on the carbs.   But cleaned then once and it starts 1or2 kicks and gets 50 mpg so dont want to mess with them.   Its still rich but oh well.
                        Terry
Offline mrblasty
  • Expertly
« Reply #4 on: January 29, 2007, 02:30:23 PM »
Got that SOB out of there, the seat was was gouged pretty bad and the o-ring was toast, replaced the ring and went at the inside of the seat with 1000 grit for a while and buffed
the needle body smooth put it all together and it works now. YAY!
These bikes pull pretty good, I was surprised.
1973 Honda CB 750
1975 GL 1000
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #5 on: January 31, 2007, 08:10:25 PM »
Hey Sparty
I just noticed you have a CJ, I picked one up not too long ago myself , couldn`t pass it up.
 You don`t see many around anymore since they were only made for two years.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline cb650
« Reply #6 on: February 01, 2007, 03:24:55 AM »
Been my experience when you say CJ 360 nobody has ever heard of them.    Was looking for a CJ tank to see if it would fit the CB.   Someone on the list used to have a nice CJ they where thinking about selling.
                                       Terry
Offline mrblasty
  • Expertly
« Reply #7 on: February 01, 2007, 09:31:27 AM »
The CJ tank should fit, it overhangs the rear strap a bit, there is a beat up tank on ebay now and i think the bidding was up around $30.00.
1973 Honda CB 750
1975 GL 1000
