Author Topic: Digital speedo and tach  (Read 16985 times)
Re: Digital speedo and tach
« Reply #25 on: February 15, 2007, 11:01:13 am »
I would be interested in knowing how it works out and to see any photos of it mounted.
Good luck with it,
cheers
Andy
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
« Reply #26 on: February 15, 2007, 11:55:18 am »
Are there any manufactures that make a two part similar to a CBR cluster, that being a analog tach and digital speed/trip/inicator?  I like the motogadget classic but I wish the speedo display was larger.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #27 on: February 15, 2007, 12:24:06 pm »
I like the motogaget classic. How much is the cost in Cash American?
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline cosmo
« Reply #28 on: February 15, 2007, 04:06:24 pm »
Anyone notice the Kawi on there?
CB550K4, XL125, C100, CB750F2, CB550F2
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« Reply #29 on: February 16, 2007, 06:08:36 am »
I didn't know digital readouts were options on these bikes?  How are you all able to make the digital gauges work with previously mechanical ones?  Well, I guess I understand the speedo solution (just like a bicycle computer, but the tach?
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #30 on: February 16, 2007, 06:21:22 am »
$505.05 at the current exchange rate.....shipping extra  :o
« Last Edit: February 16, 2007, 06:24:52 am by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline SD750F
    • My Business Site
« Reply #31 on: February 16, 2007, 06:23:01 am »
babyfood1217,
The digital indicators work by attaching a rotational sensor on a wheel or sprocket. Then you go through a calibration set-up by entering your tire diameter to determine the distance traveled in one rotation. With an internal time base you can determine your speed fairly accurately.
Tachometers use a sense wire attached to one of your coil feed wires. A sensitive amplifier then will shape the pulse signal and this is used to determine the RPM's by division.
Here is another digital option, not cheap but has some neat possibilities: http://www.garmin.com/products/zumo/
Scott
Offline tsflstb
« Reply #32 on: February 16, 2007, 07:47:24 am »
I thought there was some issue with getting the correct RPM reading from our "wasted spark" system on an electronic tach?  Since the coils fire every revolution, it would cause you to read double the engine speed.  Is that right?
If it can be used, I've thought of making a "poor mans" system using my bike computer and a cheap tach from Summit Racing.  I've got a bike computer currently mouted with the stock tach, but this one is much smaller and lighter.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG2870&N=700+1003+115&autoview=sku
Offline MrFry
    • T-Fry.com <--Under Construction
« Reply #33 on: February 16, 2007, 08:13:34 am »
Scott
neat, but not cheap! $1000+  :o
The beauty of the Vapor is that you can adjust that to work.
you set how many times the ignition fires per revolution
Offline DammitDan
  • Jedi
  • Slowly returning to the Honda flock...
« Reply #34 on: February 16, 2007, 10:36:57 am »
Will a $30 bicycle speedo not work?  I had one but the wire wasn't long enough to reach to the axle hub.
Signatures are for wimps!
Offline tsflstb
« Reply #35 on: February 16, 2007, 10:46:49 am »
Yes, actually a $9.99 bike speedo will work.  It seems pretty accurate.  I had plenty of wire to wrap around the brake line down to the wheel.
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #36 on: February 20, 2007, 11:43:37 pm »
Hmm, just an update on my Vapor.  I've had it on my Suzi for about 3 months.  Haven't driven it much since I got the Honda running good.  Anyway, I fired it up for a ride the other day and the odometer and everythijng else reset.  It does that every time I turn the key on.  Not good, I was planning on selling next month and start my CB900F or CB1100F quest.  >:(
« Last Edit: February 21, 2007, 08:23:15 pm by paxtonpony »
1969 CB750K - Wrecked
1978 CB750K - Sold
1992 GS500 Streetfighter - Sold
1975 CB750F - Sold (sniff, sniff)
1994 VFR750F - Sold
1990 GSXR 750 - Sold
1999 CBR1100XX - Sold
2000 Triumph Legend TT - Bike of the week for me?
1992 Mustang - Paxton powered (12.02@115mph on street tires) and For Sal
Offline SD750F
    • My Business Site
« Reply #37 on: February 21, 2007, 05:07:53 am »
paxtonpony,
Sounds like your digital has either an internal back-up battery that is not at the proper voltage or even not present at all. Or it has an optional ciruit on the wiring diagram that has one wire that is connected directly to your battery and a second wire attached to your ignition switch... Check this out, it is a typical design and might provide some information to help you with your reset problem... Or if I may say, it just is a poorly designed digital speedo.
Scott
« Last Edit: February 21, 2007, 10:49:23 am by SD750F »
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #38 on: February 21, 2007, 08:27:26 pm »
Ya, I'm thinking the internal battery.  Been so busy messing with the Honda.  The suzuki has become more of an obstacle in the garage than a means of transportation.  I'm going to powdercoat and respoke my wheels pretty soon so I'll have to get back on this problem soon.
1978 CB750K - Sold
1994 VFR750F - Sold
Offline MrFry
« Reply #39 on: February 21, 2007, 10:41:37 pm »
chances are the internal battery went dead - the instructions say to wire up to a constant 12v
i have just about finished installing mine and i realized i tapped into the original gauge light wires (not a constant 12v) - so it looks like i'll get to rewire that  :(
PICTURES!
Offline jevfro
  • 1975 CB750 K5
« Reply #40 on: February 22, 2007, 12:48:40 am »
looks pretty sweet... ;D I think it would be fun to fully futurize a cb750. Custom led indicators, signals, tail lights, running lights, and one of hondamans ignition units w/ led timing indicators 8) with a digital readout like that or similar.  Maybe some cool housings or something to  make it all blend in more? ???   I think I would kinda miss the old clunky mechanical versions for some reason.  :-\  Just need a project bike to try it on....  ;)Thats why once I get my original sohc running I'm looking for MORE! :o
Offline jonbuoy
    • My rebuild:
« Reply #41 on: February 22, 2007, 11:20:51 pm »
I'm working on a digital speedo trip and odo as a sideline when I can get away with it at work, using a picaxe controller I have the code worked out for trip and odo.  I haven't worked out the analogue bit between the proximity switch and the controller, I want to keep an analogue tacho - ideally an old smiths or something with a stepper or servo motor behind the face driving the needle. If it works out I will post it on here.
Offline MrFry
« Reply #42 on: February 22, 2007, 11:50:37 pm »
SHHHH!!!!
Offline MrFry
« Reply #43 on: February 23, 2007, 12:12:57 am »
Just an update: tried splicing the grounds differently (after looking at the wiring schematic) - still didn't work
so i bought some 8-pin sockets at Radio Hack and cut up the TrailTech harness.
hooked up everything normally (as in - no spliced grounds other than factory) and it works great!
My tach was bouncing around a bit so i called trailtech and they attributed it to a 'dirty signal' and offered a couple suggestions:
!.) wrap the wire around the spark plug wire only 4 or 5 times
          - same result
2.) connect the + lead to the + input on the coil
          - same result
so i still have a bouncing tach
i just finished hooking up the speedo sensor but havn't had time to test it
drilled a hole in the rotor base for the magnet and hacked up the dust shield (?) around the rotor to hold the sensor
i think i'm going to ditch the dust-shield and make a bracket
the installation instructions only have you calculate the circumfrence of the tire for the input of the compute (you say your Circumfrence is __ and it figures out the rest).
wouldn't it depend on where you install the sensor in relation to axle or center of the wheel?
perhaps i'm looking too far into this...
oh, and in the process i discovered the brake line was seized on the caliper (and the PO had already broken the bleeder) - so i had to swap the ends of the line. I will see if my local place will make me a new one.
also recieved my EBay tach-plug  ;D
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #44 on: February 23, 2007, 05:00:02 pm »
My tach bounces all over the place too.  I'm inclined to think it's a guess-timate tach anyway.  The GS redlines around 12 and I've seen the tach at anywhere from 8k to 16k when I know I'm around 12k.  I just use the audible tach.  I generally shift right before the valves float when I'm in my angry mode.  99.9% of the time I'm just tooling around town so it doesn't matter.
BTW, I like the way yours has indicator lights.  I bought mine when they first came out and were only 99.  They didn't have your version.  Looks good!
1978 CB750K - Sold
1994 VFR750F - Sold
Offline mrblasty
  • Expertly
« Reply #45 on: February 23, 2007, 08:55:17 pm »
hey there, sorry for abandoning the thread, I've been really busy.  The sensor cable I have is a little different than the one pictured, I also ordered a set of suppression core plug wires for two reasons my plug wires are about shot and to reduce some of the interference
that may be the cause of the tach bounce, I think you had that Idea paxtonpony.  hopefully the weekend weather will allow for some drive way time getting down to the shop these days is going to be tough.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline MrFry
« Reply #46 on: February 24, 2007, 04:12:48 pm »
i've been talking to them everyday this week
now they are sending me a new tach lead with resistors built in that i attach directly to the coil
we shall see how that goes
the indicator lights can be bought separate - http://www.trailtech.net/022-PDA.html
they were a bit of a pain to install though - the quickest and easiest way would be to cut up the harness that comes with it and get an 8-pin connector from radio hack
Offline jonbuoy
    • My rebuild:
« Reply #47 on: March 08, 2007, 11:35:51 am »
I've been put onto these guys in my never ending search for a retro style set-up, these still look too modern but the prices are good and there is a wide selection, you'll have to go easy on the guy as his English isn't too good - damn site better than my German though!  He lists on Ebay UK as well and a little cheaper:
http://www.scooter-discounter.com/
Offline MrFry
« Reply #48 on: March 08, 2007, 12:00:26 pm »
in my Gauge search i stumbled across the KOSO gauges as well - unfortunately the US selection was a bit limited.
they looked like good gauges though.
i really liked this one
but it isn't available over here
Offline jonbuoy
    • My rebuild:
« Reply #49 on: March 08, 2007, 12:05:02 pm »
Yeah thats a nice layout, colouring is still a bit futuristic for me.  If he would do something a little simpler - a plain black or white tacho with a small analogue or LCD speedo next to it I'd go for it.
