Author Topic: Preparing Frame to Paint 500 K0  (Read 537 times)
Offline cb
« on: February 26, 2019, 09:11:21 AM »
When removing rust from a frame, is it better to feather in to the original paint, leaving as much original paint as possible, or to remove all paint and start fresh?  About 1/4 or less of the surface area needs to be taken down to metal and feathered.  I will be using a media blaster to remove the rust.  I plan to repaint the entire frame.  BTW, does anyone have a favorite media to use to remove rust from a frame?
Re: Preparing Frame to Paint 500 K0
« Reply #1 on: February 26, 2019, 09:34:39 AM »
I usually figure the original frame paint is tough as nails, so if it does not get all sanded off in the prep process, i just paint over it.
Offline tlbranth
« Reply #2 on: February 26, 2019, 09:59:32 AM »
I remove all the paint using a sandblaster. HD has a 96lb bag of stuff called Silica Sand that works very well. It's fine enough to not clog the gun and has sharp edges to cut fairly quickly. It'll probably take 2 bags to do a whole frame (as I recall). I spread a tarp and reclaim about 50% of the sand for reuse. The rest becomes part of the yard.
Blasting is waaaaay easier than anything else I've tried in the past.
Good luck.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline cb
« Reply #3 on: February 26, 2019, 03:56:02 PM »
thank you both for sharing your point of view.
Offline jakec
« Reply #4 on: February 26, 2019, 04:09:48 PM »
We had a good discussion here recently
http://forums.sohc4.net/index.php?topic=175167.0
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline cb
« Reply #5 on: February 27, 2019, 07:09:03 AM »
Thank you, that is helpful.
