Author Topic: Will Guts from CB750 Diecast lower end fit in Sandcast cases?  (Read 796 times)
Offline Impala
 Can one take all the internals from a CB750 diecast motor lower end and transplant them into Sandcast cases? Obviously the clutch cover will need to be a 9 hole. Cylinders and head should also be early style. Will diecast oil pan fit on sandcast? Any other issues for swap? Is there a better year diecast motor to use for the donor parts? Thanks for info.
Re: Will Guts from CB750 Diecast lower end fit in Sandcast cases?
« Reply #1 on: March 09, 2019, 01:18:24 PM »
Oilpan  may be different.
 Shifter mechanism had a change on early diecast, if you use all of it, it should work..
« Reply #2 on: March 09, 2019, 01:40:03 PM »
The oil pan is for sure different, the clutch pack may protrude further depending on what year it is. A 10 hole cover will bolt on. I've made a 9 hole cover from a 10 and plan to make a couple more soon. And what Frank said about the shifter.
« Reply #3 on: March 12, 2019, 04:01:27 PM »
 The oil pan is nearly square requires a different gasket. I made my own.
Offline Swoop
« Reply #4 on: March 12, 2019, 05:48:58 PM »
Diecast can be from 69 to 78....,alot of changes to be considered. K...F....Depends on the year.
« Reply #5 on: March 12, 2019, 06:28:11 PM »
 I always considered diecast to be the K0's made after Sandcast. Neither is a totally correct term, they say sandcast is really gravity cast but there wasn't a K0 until after there was a K1, they were just K.
 I also agree that's just be my opinion which may or may not agree with anyone else's.
