Author Topic: Mini Trail 50 1969-70  (Read 3672 times)
Offline kap384@telus.net
Re: Mini Trail 50 1969-70
« Reply #25 on: May 21, 2020, 03:55:19 PM »
Lookin good
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #26 on: May 22, 2020, 10:10:20 AM »
I had a blue 69' just like it  8) bought it used from a dealer in CT. for $40 back in the early 70's  :)
I fixed it all up,installed parts that were removed(it was a recovered stolen bike and the owners didn't want to pay the dealer to make it complete again)and then rode that little bike all over N. Stamford,CT. with no license or registration..  :D
Yeah baby...the good old days. ;D
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #27 on: May 22, 2020, 02:58:37 PM »
Very cool old Honda
It seems you don’t see near as many survivors of other brands, I guess it’s just the shear numbers of bikes they have produced.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #28 on: May 23, 2020, 06:38:36 PM »
Thanks all for reading along.
Changed the front tire/tube today.  Front brake got a new cable as well.  One of the many falls had bent the headlight ring.  Was able to use small dead blow hammer to get it close to round.  The wires connecting the headlight to the harness had become frayed and the ends were missing.  Replaced the ends and cleaned the headlight contacts.  Started the bike and the headlight works now, both brake levers light the brake light.  Next electrical gremlin will be the tail light.
Bike has been shifting rather hard into first gear.  Alas the bike did not like it when I  reduced the idle speed and died.  Increased the speed on the idle but still not starting.    :(  Will try again another day.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline MD
    • MN North Woods
« Reply #29 on: June 07, 2020, 03:23:10 PM »
Well decided to order a new spark plug and the air filter.  Installed them yesterday but could not get the bike to start.  Went out today, drained the gas from the carb and tried again.  No go so pulled the plug and verified spark, squirted starting fluid down the spark plug hole and still nothing.  Full throttle no choke, full throttle choke.  full throttle and partial choke.  The last one eventually got a bark.  Switched to partial throttle and kept on kicking until things warmed up enough to stay running.  Turned the choke off and adjusted both the air and throttle screws.
My guess is that the carb was set too rich.  Initial runs were without an air filter so adding a filter made it more rich again.  When it stops raining tomorrow or Tuesday, will see if it will start with choke on and allow the choke to be open after a minute.
-MD
Online grcamna2
« Reply #30 on: June 07, 2020, 04:13:23 PM »
-MD
Maybe get/borrow a compression gauge with a 10mm plug end adapter after you run it(valve clearance ok?)next time and it's warm,I'm curious what it will yield.
Offline MD
    • MN North Woods
« Reply #31 on: June 07, 2020, 05:41:16 PM »
-MD
Thanks for the suggestion.  Did check valve clearances already but don't have a compression tester.  Borrow or buy?  It may be time to add one to the toolbox.
-MD
Offline MD
    • MN North Woods
« Reply #32 on: June 11, 2020, 05:56:42 PM »
Bike sat for 4 days.  Went out and turned on the gas and the choke.  Started on first kick.   ;D
Time to work on the tail light.
-MD
Offline MD
    • MN North Woods
« Reply #33 on: June 25, 2020, 03:51:24 PM »
Replaced the half burned out bulb with a LED bulb.  Now have both tail and brake lights.   :)
I would like to add led turn signals.  Does anyone have recommendations for a 6 volt system?
Thanks,
-MD
