Author Topic: 500 K0 Rusty Alternator Rotor  (Read 481 times)
Offline cb
« on: March 14, 2019, 08:16:34 am »
I discovered that I have a fairly rusty alternator rotor (see photo).  Does this appear to be bad enough to need rust removal?
If so, shall I sandblast it or take a wire wheel to it?
Thank you.
Offline Bodi
Re: 500 K0 Rusty Alternator Rotor
« Reply #1 on: March 14, 2019, 09:10:16 am »
Go nuts. The rust will not affect anything except appearance. You can't hurt it without really trying. Soaking in a rust remover will be OK. Same with a wire wheel, steel wool, Scotchbrite, abrasive blasting - just lay off the tapered hole as that's a precision fit on the crankshaft end.
Offline cb
« Reply #2 on: March 14, 2019, 09:35:27 am »
That's good to hear; it is what I was hoping to hear.
Thank you for taking the time to reply.
Online Stev-o
« Reply #3 on: March 14, 2019, 02:50:45 pm »
I would just wipe it down with acetone and/or oil
'74 "Big Bang" Honda 750K [836].....'71 Honda 750K project.....'76 Honda 550F.....K3 Park Racer!......and a Bomber!............plus plus plus.........
« Reply #4 on: March 14, 2019, 04:07:48 pm »
Be advised DO NOT turn the engine over continuously with the alloy cover off or the oil gallery plug will disapear somewhere never to be found and a large slippery puddle apear on the floor!!
Offline rosewood
« Reply #5 on: March 14, 2019, 08:12:17 pm »
Lol! I primed my engine with a drill on that alternator nut....as soon as the pressure built I had oil all over me...then I spent the next hour going through my boxes of spare parts thinking I forgot to put that gallery plug in...eventually found it on the floor...
« Reply #6 on: March 15, 2019, 03:18:46 am »
Yup! Tee shirt and Video there!!
