What exact Castrol oil it is? For cars?
To me that's irrelevant. Back then, the oil that every dealer in Holland used to service Japanese (and not only Japanese) bikes was Castrol's GTX2, not a specific 'motorcycle oil' either. Some seem to think that if you select an oil that does not say JASO-MA on the package, you
automatically will face trouble with the clutch*. This is not the case. Some wet clutches are sensitive for this, some are not. The only bike I ever experienced a minor clutch slippage, was a Yamaha XS650. I adviced the owner to change the oil for one used in Yamaha workshops and he later informed me that after the oilchange the slippage had gone. What I look for in an oil above all, is its capacity to preserve the rubbers and the valve stem seals in particular. Every year my bike is hibernating for some five months. The only time I had O-rings (oilpump) leaking, was when I had the synthetic Mobil1 in there. I've noticed that the shifters rod seal is also sensitive to what oil is used. There's a drip every now and then, but not like before, when oil gushed down whenever I removed the sprocket cover. Will Castrol's GTX High Mileage cure the typical - at least for a CB500 - sweating at the head? Not that I've experienced, but it hasn't worsened. It usually occurs after cold starts following a long period of inactivity and seems to decrease when I ride daily. It's not sweating to a point that I have to fear for my pants, so I can live with it.
it seems that castrol is syntetic?
To serve you well, I went down to the basement and had a look at the package. New to me: it
now says 'synthetic technology'. Not on the old package. Nothing to worry about imo. 'Semi-synthetic' is a similar term.
* If a package does not say JASO-MA, it does not automatically mean that the oil doesn't meet that specification. It could well be that the oilcompany rather wants you to turn to their 'specific' and usually higher priced line of motorcycle oils. Who knows?
