Author Topic: Honda CB750 Mirror Mount (Damper?)  (Read 557 times)
Offline BenelliSEI
  • 1969 cb750
« on: March 19, 2019, 09:25:15 AM »
One of my bikes came with a small extension mounted under the left side (clutch lever) mirror. Best described as a small, chrome barrel, about 20 mm in diameter and 30 mm tall. One end has a stud that screws into the hole in the clutch lever perch. The top end is drilled and tapped to take the mirror stem. It is rubber filled, like an isolastic bushing (Dunlop called them “metalastic”).  It doesn’t really take out or add vibration, but it DOES raise up the left mirror and make it more useful. It also makes it the same height as the RHS, raised up on the master cylinder. Makes a difference.
Anyone seen these for sale anywhere? I’d like a few more........
Offline lash
Re: Honda CB750 Mirror Mount (Damper?)
« Reply #1 on: March 19, 2019, 09:30:53 AM »
Here they are John..  I have them on all my bikes
https://fortnine.ca/en/emgo-mirror-riser-10mm-chrome-20-28113
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: March 19, 2019, 09:56:32 AM »
Thanks! The one I found actually has a rubber centre core......
« Last Edit: March 19, 2019, 12:49:44 PM by BenelliSEI »
« Reply #3 on: March 19, 2019, 10:32:15 AM »
 That is a riser not a damper... Suzuki in the 70,s  I think it was , had rubber mounted type.
FOUND THEM   bike barn..
« Last Edit: March 19, 2019, 10:37:27 AM by 754 »
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: March 19, 2019, 12:51:22 PM »
I think that’s it. Thanks!
