Author Topic: clutch cable routing CB750K6  (Read 509 times)
Offline BasicPoke
« on: March 23, 2019, 10:25:11 AM »
Hello.  Do I have this clutch cable routed correctly?  Seems it should not be in front of the speedometer, or is this normal?  It's not an OEM cable, I don't think.  CB750K6.  Thanks.
FYI, I am asking questions on this forum instead of facebook because this can be searched by others for years to come, and the posts come up in google searches.
Offline Progas
Re: clutch cable routing CB750K6
« Reply #1 on: March 23, 2019, 01:38:18 PM »
Looks good, however the cable should be on the front side of the down tube, which will get rid of that twist by the neck.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: March 24, 2019, 04:38:40 PM »
Agreed..... in your photo #3, I try to get it to run down the space in front of the two thru’ bolts, holding the triangle engine plate. You can hide a zip tie there, so it can’t move. Keeps the cable cooler too, if it’s out front.
Offline BasicPoke
« Reply #3 on: March 30, 2019, 11:17:59 AM »
Thanks guys.  Just wish it wasn't going in front of the speedometer.
