Author Topic: carb floats  (Read 843 times)
Offline Fourme
carb floats
« on: March 23, 2019, 03:22:51 PM »
In the process of rebuilding the carbs on a 1972 cb750.  The floats seem to be in good condition.  Should these be replaced as a matter of course, or is it acceptable to use the old ones?
Thanks.
Chris
Online bryanj
Re: carb floats
« Reply #1 on: March 23, 2019, 03:28:46 PM »
As long as they dont leak they are fine.
Re: carb floats
« Reply #2 on: March 23, 2019, 03:32:50 PM »
 Check the spot where they contact the pin of the float valve  for a dimple worn in it, that can cause it to be a bit sticky. Otherwise go for it.
Offline pjlogue
Re: carb floats
« Reply #3 on: March 23, 2019, 04:12:03 PM »
That float look great.  If the foam (or what ever the black part is made of) is intact and the tang isn't dimpled all you need to do is check that the float sits square on a flat surface.  i.e. the arms aren't tweaked so one float arm is higher/lower than the other.  Smooth off any sharp edges on the brass where it might catch on the float pillars.
-P.
Offline Fourme
Re: carb floats
« Reply #4 on: March 23, 2019, 06:35:58 PM »
Thanks everyone for your advice.
Re: carb floats
« Reply #5 on: March 24, 2019, 05:42:32 AM »
Just for future reference for people someday searching if you have old, bad and leaky brass floats in a K1 750 (1971) the black foam are a direct replacement and no more worries.
