Author Topic: CB400F All Balls - Washers and Order?  (Read 6427 times)
Offline rupaulpierce
Re: CB400F All Balls - Washers and Order?
« Reply #75 on: July 15, 2019, 12:49:34 PM »
Sorry, I'm not understanding the question. What do you mean by cups?
Cup is just another term for the races. Got it all set up, feels a little “floaty” so may need to tighten the spanner nut.  I was able to get the spanner nut on without grinding off the notches, though I had to compress the assembly without the upper seal once before finally installing the spanner nut with the seal.
Offline jakec
« Reply #76 on: July 15, 2019, 02:22:03 PM »
I was able to put the spanner nut on without grinding was well, but it only left 1-2 turns of threads for the chrome top nut. I ground off the notches to give myself more purchase there. Also I think the pressure will be better distributed on the seal without the notches.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
