Author Topic: Who's running a Delkovic exhaust?  (Read 1213 times)
Offline Scott S
« on: March 26, 2019, 05:32:32 AM »
 Curious about your set up with the Delkovic. Their website says no jetting is required. True?
 I picked up a used full system with the smaller straight-style muffler. I have a stock CB550 with a UNI filter in the stock air box. I will be running PD carbs. I though about going up on the mains from 90 to 95 and adjusting the mixture screws.
 What's everyone's experience with the Delkovic system?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline slikwilli420
  • Master of Disaster
Re: Who's running a Delkovic exhaust?
« Reply #1 on: March 26, 2019, 06:04:09 AM »
My brother has one on his '77 750K and he loves it. Easy install and quality piece. Typically, unless you push more are in (intake) you won't need to rejet. The exhaust only helps move out what the engine burns and if you arent sucking more air in you don't need more gas.
Offline Scott S
« Reply #2 on: March 26, 2019, 06:50:51 AM »
 Does the '77 750 have the "lean" carbs, too? That's the only reason I'm thinking about going up on the mains.... the PD carbs.
'71 CB500 K0
'81 Yamaha XS650
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: March 26, 2019, 07:12:28 AM »
I just put a Delkevic on my 750-F1, but haven't had a chance to ride it yet.
The PD carbs on the 550 are set up leaner than the prior carbs so I don't think that bumping the mains up 5 would be a problem, especially given that the 77 550F with the factory 4-1 and non-PD carbs ran a bigger main jet than what you are talking about here.
« Last Edit: March 26, 2019, 09:04:27 AM by Bankerdanny »
Offline lafindufondu
« Reply #4 on: March 26, 2019, 07:14:49 AM »
I had the delkevic 4 into 1 on my 74' cb550 and on my 75' cb750, I didn't rejet and the bikes ran great.  I went with the small straight muffler on the second set I ordered.  The system installs easily and sounds great.  Can't beat the price.
Offline beemerbum
« Reply #5 on: March 26, 2019, 08:03:42 AM »
I installed a Delkevic on my K7. I never touched the jets and the bike runs great. The entire Delkevic system weighs just a hair more than just one of the stock pipes. I did like the 4 into 4 look but my stock system was patched with beer cans and duct tape. This looks so much better and sounds great
« Reply #6 on: March 26, 2019, 08:04:57 AM »
Stock jetting in my Mikuni's!
Offline RustyF
« Reply #7 on: March 26, 2019, 12:16:55 PM »
I have a Delkovic 4 into 1 on my 78 550.  Running stock air box & paper filter, I cleaned the carbs and re-jetted up 1 size on pilots and mains...the bike ran very rich with an inconsistent idle, then changed back to stock pilots, cleaned up the idle and slow-mid range but over 5000 was still rich...jetted back to stock mains and 2.5 turns out on the pilots and the bike runs great.  Hope this helps
1978 CB 550 K
Offline Scott S
« Reply #8 on: March 26, 2019, 12:51:07 PM »
Hmm.... so the stock 90 mains on the PD carbs might be fine?
'71 CB500 K0
'81 Yamaha XS650
« Reply #9 on: March 26, 2019, 12:56:39 PM »
Yes, PD carbs, and he did not rejet or make any adjustments to the carbs.
Offline BenelliSEI
  • 1969 cb750
« Reply #10 on: March 26, 2019, 06:07:44 PM »
Mine works great, “as is”!
« Reply #11 on: March 26, 2019, 08:40:21 PM »
 I put a Hooker 4 into 1 on my 750 in 1975..
 And K&N pods, except they were not called pods and had rubber ends.,.. the first ones..
Stock jets and it ran great, but my buddy was always just a bit quicker on his K3, with a Jardine.  He weighed about 75 lbs less than I.
 Everybody always talked about running bigger jets., so after running it about 4 months like that, I put 120,s in
Oh my Lord, it was a real difference, and now  I could beat my buddy..
And then a few days later, we had a bad mishap, he ran into me, me  turning, him closing up at 95 mph.. total both bikes, broke the cases on both of them..
 But back to the pipes.. what do you want... a pretty lighter pipe ? Or Performance ?
 To me it's a waste if it does not make more power. If it breathes better, it should handle  more jetting,
 I can't see a power increase without it.
 At any rate, always check your jetting with a pipe  or other major change..
« Last Edit: March 28, 2019, 05:59:12 PM by 754 »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #12 on: March 28, 2019, 09:57:20 AM »
98's would be great  8)
« Reply #13 on: March 28, 2019, 11:36:57 AM »
I put a Booker 4 into 1 on my 750 in 1975..
Frank, a pipe can only put out what gets put in, though more efficiently. If it is restricted to stock intake, I don't see why jetting would do anything.
« Reply #14 on: March 28, 2019, 11:59:26 AM »
 If a pipe is left restrictive  it can produce more power.
 Are you only running a 4 into 1 on Superbikes go save weight.
 Pipes either work or don't some good some bad..
I have one set of pipes  with smaller primaries that greatly changes the way the motor runs.
Offline Gene
  • Chat enuf you too can be a
« Reply #15 on: March 28, 2019, 03:41:35 PM »
just bookmarking this thread. this is something I may be looking at in coming years. Not for the weight, not for the power, but for the stainless steel.
*1973 CB750K3 (Bow)
« Reply #16 on: March 28, 2019, 06:14:53 PM »
 Fwiw
Glencoe dragstrip Sturgis SD.. me on a 80 R 100 RT.
Make  baseline run. Then pull airfilter .. 3/10 difference in 1/8 mile.. that is about 1/2 second in the 1/4 mile
 A lot really for a 0 dollar change.
 Then I pulled  the mufflers, but I have no jets with me. BTW mufflers are pretty quiet, so i imagine that is a result of being restrictive.  I make a few more runs, the time  stays about the same, but its louder now, and the crowd likes it, you can hear it now and it sounds good. And getting the wheel up into second, and a bit into third, they like that stuff.. but it feels lean  like it needs more fuel.
 So I think, maybe a burnout is in order, after all we are at the drags.  And I do it,  knowing full well that I cannot  drop the clutch as it will head skyward..... it's all part of the show..
 But unfortunately that wounded my clutch... not can't ride it home wounded  but give it thru a few hard shifts and it slips.
 Can't help but think I would have picked up some time  with one or two sizes up on the mains..
