Author Topic: Great book for advice on detailing motorcycles  (Read 1000 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: January 24, 2007, 09:16:40 PM »
I spotted this in a local used book store. I suppose it is still in publication. Great chapters on all facets of detailing motorcycles.
1978 CB750K8; 1970 CB450
Offline DammitDan
  • Prodigal Son
  • It lives!
Re: Great book for advice on detailing motorcycles
« Reply #1 on: January 25, 2007, 10:53:28 AM »
It goes beyond common sense stuff?  Doesn't seem to me like detailing is all that complicated...
Just takes time and elbow grease in my experience.
CB750K4
Offline Raul CB750K1
« Reply #2 on: January 25, 2007, 03:51:17 PM »
I bought it a while ago. Have some good tips but I can't use it further than that - the products mentioned in the book are not available in Spain...  ;D
Raul
Offline Klark Kent
« Reply #3 on: January 25, 2007, 04:46:24 PM »
i heard a 'motorcycle detailing secret' the other day:  rubbing aluminum foil on chrome will remove pitting.  havent tried it but thought about how steel wool will get into the pores of aluminum so its bad to use it on our cases, as the brittle bits of the steel will be absorbed into the aluminum, and this seems to be taking advantage of that principle by absorbing the brittle bits of the chromium steel (the rust) into the aluminum foil?
hey heres a better idea: turn this thread into a detailing secrets thread.   if things dont pick up, raul could start transcribing that book.  ;D
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #4 on: January 25, 2007, 05:32:52 PM »
Uh, you can remove varnish from silver using aluminum foil, warm water and baking soda?
CB750K4
Offline Jonesy
  • Shop Rat
« Reply #5 on: January 25, 2007, 05:45:02 PM »
I think I saw the MythBusters do the Aluminum foil/Coca-Cola trick. It seemed to work pretty well.
Offline gregwaits
    • waits music
« Reply #6 on: January 25, 2007, 06:25:10 PM »
I was jusy thinking about trying coca cola on my wheel rims.
« Reply #7 on: January 25, 2007, 06:51:52 PM »
You need to add salt to that to mix. It is actually a plating process. The silver oxide plates itself to the Aluminum. Works very well.
« Reply #8 on: January 26, 2007, 12:12:26 AM »
Steel wool will remove rust from chrome without scratching the chrome. Obviously, if the chrome has been pitted it would be to late, but for surface rust it's just a matter of seconds.
Check this mirror of my CB350. Sadly it was pitted and an replacement was the way to go...
Raul
Offline Uncle Ernie
« Reply #9 on: January 26, 2007, 09:48:22 AM »
Deatail?  You mean- as in clean?!
 a-HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA  >whew!< *gulp* uh- HAHAHAHAHA HAHAHAHAHAH !
                                 ohhhh my,     that was good...
