Author Topic: larger oil passsage orings for aftermarket head gasket  (Read 420 times)
Offline Redline it
  • thread killer
« on: March 28, 2019, 02:35:37 PM »
is it only .2mm larger and what kind, buma or whatever that one is called, or oil/heat resistant. where do i get some, anyone have a large supply of them? I don't really want to order 40 of them from an o-ring distributor. thanks a lot.
i could never find the paper with the bore specs and attempting another 24 of those measurements...after the first check, i was like, done with that. i did find the elongated oring on the special nut was totally decomposing somewhat. took a month to get the base gasket off, finally had to use a gerber filet knive. loctite chisel works as good as permatex gasket remover spray, that's infant safe, pets too (junk.) tuned the valves up. assembled them with 15-40 honda motor oil, then seen the moly disulphide grease instructions. so valves gotta come out again to put that on. so i don't get that part wrong, is there any special way to apply the thin film? just put it on the valve stem? or pack a tiny amount in the guide? it's coming right along. parked for 3 or 4 months now. sucks.
Offline Old Scrambler
Re: larger oil passsage orings for aftermarket head gasket
« Reply #1 on: March 29, 2019, 09:21:54 PM »
Torque-Squish should take care of the 0.2mm unless you find an O-ring only 0.1
Just put the molly on the stems.....................
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Redline it
  • thread killer
« Reply #2 on: March 30, 2019, 08:26:35 PM »
thank you.
